MF50 Perkins 4 Cyl Won't Start!
this thread has 2 replies and has been viewed 432 times
Old 09-20-2018, 06:50:59 PM
JohnKaz JohnKaz is offline
Default MF50 Perkins 4 Cyl Won't Start!
Hi All, We have a circa 1965 MF 50 tractor with a 4 cyl perkins diesel. When parked up it was running perfectly, but after leaving it for 3 or four weeks she wouldn't even turn over ( Just a solenoid click). I Have removed the starter which checked out OK). I attempted to turn the flywheel with a crowbar but it won't budge. Has been regularly serviced, has good oil pressure and has never got hot. Any suggestions on fixing this would be greatly appreciated.
Old 09-20-2018, 11:29:37 PM
Heins Heins is offline
Default Re: MF50 , Perkins 4 Cyl Won't start !!
Did water get into the cylinders?
Old 09-21-2018, 07:35:03 AM
Tom Marshall Jr.'s Avatar
Tom Marshall Jr. Tom Marshall Jr. is offline
Images: 1
If it has glow plugs take them out to check for fluid in cylinders when you try the pry bar again.
Perkins 6-354 dadam2308 Vintage Diesel and Oil Engines 3 02-23-2018 10:48:28 PM
Perkins Cold Start Greg Moore Kohler Generators 15 01-01-2016 11:16:06 AM
kohler perkins 12 or 15 kw need to know how to start without starter awab Kohler Generators 9 02-10-2013 05:58:03 PM
need perkins help StmEngn Welding Shop 1 11-23-2011 09:52:40 AM
Perkins AA40714 will start only with ATF in the filter biggy Multi-Cylinder Stationary Engines and Power Units 4 11-29-2010 03:46:18 PM
