Wisconsin Engines
Wisconsin BKN, Looking for Connecting Rod Bearing Shell
this thread has 7 replies and has been viewed 435 times
Old 10-01-2018, 03:41:58 PM
DustyBar DustyBar is offline
Default Wisconsin BKN, Looking for Connecting Rod Bearing Shell
Does anyone know where I can get a shell type rod bearing for a BKN engine? The bearing is completely missing on this engine I'm working on but the crank looks fine. The rod is broached for the bearing locking tabs. Rumor has it that a neighbor took it to school for a shop project several years ago. A couple of other parts were lost but I've found usable items or made my own (no, the kid does not work as a mechanic anywhere). Does anyone know what the rod bearing part number should be so I can look on EBay? My manuals must be for older BKN engines only since none of them show a bearing shell.
Old 10-01-2018, 04:55:57 PM
Default Re: Wisconsin BKN, looking for connecting rod bearing shell
Not dead positive but I think the ARC Billet Racing connecting rod for the flat head 5 H.P. Briggs engine uses the same insert as the BKN Wisconsin. You can call them and ask, 1800-521-3560
---------- Post added at 03:55:57 PM ---------- Previous post was at 02:57:41 PM ----------
If you don't have any luck, I'll look and see if I have a good used set I can give you. Let me know.
The Following User Says Thank You to Pat Barrett For This Post:
Old 10-02-2018, 02:44:47 PM
Dodd Dodd is offline
Default Re: Wisconsin BKN, Looking for Connecting Rod Bearing Shell
You can get them from Wisconsin too. I looked at the parts list they have on their website, and it doesn't show a part number but it does mention them.
Aaron
http://www.wiengines.com/distributors/
Old 10-02-2018, 06:26:01 PM
I contacted ARC Billet Racing and they said their 6392ca bearing shells should work on the BKN connecting rod.
Bolens Parts & Supplies say they have or can get the bearing I need, although it is not listed on their site.
Old 10-02-2018, 06:48:10 PM
Thanks, Dusty, I've got a new set of those 6392 bearings, if you want them and have not found any. Mail me through this site if you wish.
Old 10-02-2018, 08:08:44 PM
I ordered from ARC since I need two sets. Thank you for your offer. I'll post again after I see how they fit.
The Following User Says Thank You to DustyBar For This Post:
Old 10-05-2018, 08:34:10 PM
The ARC bearings arrived and are a perfect fit. Three days and I had them in my hands. Can't beat that. Tomorrow I need to get some fresh fuel and take care of some fuel line issues. I have had it running a few seconds on fuel just sprayed in to the cylinder.
Old 10-06-2018, 06:44:58 AM
That's great. I thought they would, you said you needed 2 sets, ???
Bronze connecting rod bearing Steve Kreiner Antique Gas Engine Discussion 12 12-22-2014 12:17:11 AM
Connecting rod bearing Steve Kreiner Antique Gas Engine Discussion 0 08-17-2012 09:55:13 AM
Reducing Split Shell Bearing Babbitt outofspec Machine Shop and Tool Talk 22 12-15-2009 05:23:17 PM
Delco 850 Connecting Rod Bearing Jacob Warner Generators & Electric Motors General Discussion 0 10-26-2009 03:10:11 PM
Bearing clearance on a 3hp Z connecting rod Ray Cardoza Antique Gas Engine Discussion 6 02-27-2009 06:16:29 PM
