31 Truck
this thread has 4 replies and has been viewed 778 times
Old 10-04-2018, 06:04:31 PM
AgTeacher AgTeacher is offline
Default 31 Truck
Can a Wiko EK points be reset without taking the mag off the engine? and if so would someone tell me how to do it?
Old 10-04-2018, 09:02:03 PM
Default Re: 31 truck
Too little information.
What engine is it on? Some engines give you easier access to the mag itself. Some drives allow you to drop the armature further than others.
At any rate, you'll need to pull the armature down far enough to get to the lock nut on the points. Here's the service instructions for the EK:
http://www.oldcroak.com/ek-magneto-rx/
Do you "know" that the points need adjusted? There are only two bolts holding a WICO EK on the engine. Why not just remove the mag and make your life easier?
Kirk
Old 10-05-2018, 12:50:30 PM
Default Re: 31 Truck
I was stupid and move the points. Trying to get them back and cant even get them close. Gun shy in removing the mag and messing something else up
Old 10-05-2018, 02:25:01 PM
Removing the mag shouldn't "mess anything up". Just pay attention to the location of any springs that may fall off (depending on what engine you are working on). You can unbolt the mag, make the necessary adjustments, and reinstall the mag without affecting the timing. WICO EK mag drives rely on the drive design to determine timing; the mag is along for the ride.
Kirk
Old 10-07-2018, 12:23:17 AM
cobbadog cobbadog is offline
Take a heap of pics of how your EK is fitted so you have a reference when going back together.
MacDonald Truck At Hays Antique Truck Museum Peter Short Antique Autos and Trucks 9 02-21-2017 02:54:42 PM
IHC Truck HELP? Todd Hodges Antique Autos and Trucks 9 03-05-2016 07:39:25 PM
Car or truck. What is it? Oldtech Antique Autos and Trucks 6 09-05-2010 09:31:06 PM
Help Id this old truck Mike in CA Antique Autos and Trucks 9 02-01-2010 06:51:15 PM
