Oil Field Engines
McEwen Bros half breed ignition -- need help
this thread has 2 replies and has been viewed 358 times
Old 10-10-2018, 10:29:17 AM
farmacresinohio farmacresinohio is offline
Default McEwen Bros half breed ignition -- need help
Need some advice. I am working on this McEwen Bros. half breed ---- running on a mag and seems to prematurely "double fire" (after 30 seconds of running near perfectly) and then stalls to a stop.
So I replumbed it completely to now include accumulator tank and Garretson KN demand regulator. Yes, the accumulator is between the gas grill regulator and demand regulator. Yes, I am using a 100 lb propane tank. Diamond valve is located after demand regulator (at intake). Question -- what is the cause of the additional ignition? I think it occurs BTDC, but unsure. Could a faulty intake valve result in this? Wrong spark plug? too rich? Currently, the mag ignites ATDC. Terribly confused. I notice the RPM's increase gradually before this "double fire" event happens. I can send pic and/or video if needed. Tony Skowronek, Southern Ohio.
Old 10-10-2018, 01:04:35 PM
Default Re: McEwen Bros half breed ignition -- need help
The ignition should take place before TDC, 5 or 10 degrees advanced should be fine for running slow.
What is happening with your engine is that as the engine speeds up the fuel mixture will get lean. When it does that, the burning fuel in the cylinder will burn so slowly that it will still be burning when the when the air and fuel is transferred from the scavenging side of the cylinder. That lights off the charge that is in the scavenging side of the cylinder which is what you are experiencing.
It is common for two cycle engines running on propane to experience this. Running the engine richer helps as does throttling the air down so it makes less power. A load on the engine helps as well.
Old 10-10-2018, 01:19:42 PM
Brian Lynch's Avatar
Images: 23
McEwen Bros. engines run better on a hot tube. That is how they were designed to run. They will run OK on a mag too. If you have the hot tube set up, try a 6" tube first. Work your way down to 4" to see how it reacts. Long tubes fire earlier, shorter tubes fire later. Where you heat them makes a difference too. Heating one at the bottom will fire sooner than one heated at the top end
The Following User Says Thank You to Brian Lynch For This Post:
Twin cylinder 4 cycle McEwen Bros., Wellsville, NY Brian Lynch Oil Field Engines & Related Equipment 2 10-18-2016 03:57:27 PM
Oil field related advert. item. McEwen Bros. Brian Lynch Oil Field Engines & Related Equipment 0 04-26-2012 09:59:38 PM
Innis / McEwen Bros. Half Breed bits & pieces Brian Lynch Oil Field Engines & Related Equipment 5 02-20-2011 09:17:08 AM
McEwen Bros. Steam Brian Lynch Steam Stationary Engines, Traction Engines, Steam Boats 4 02-20-2008 03:50:33 PM
McEwen bros. engines JIM WICKHAM Antique Engine Archives 0 02-24-2000 05:25:50 PM
