Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Unidentified Engines Post your photos and questions about your unknown engine and look for answers here.
Unknown UK upright single, curved spokes...
this thread has 10 replies and has been viewed 1107 times
Old 10-13-2018, 01:50:57 AM
Robt.'s Avatar
Robt. Robt. is offline
Default Unknown UK upright single, curved spokes...
Any help appreciated on this one!
ID:	320708   Click image for larger version
ID:	320709   Click image for larger version
The Following 4 Users Say Thank You to Robt. For This Post:
Old 10-13-2018, 08:34:04 AM
Craig Gillingham Craig Gillingham is offline
Default Re: Unknown UK upright single, curved spokes...
A Ransomes Wizard?
Old 10-13-2018, 11:33:16 AM
Philipagri Philipagri is offline
It does indeed look like a Ransomes Wizard. Ransomes Simms and Jeffries produced a few of these in the 1920's but they were not very successful even though they were a close copy of the Scandinavian Brons engine. The surplus stock were largely exported to Australia and New Zealand in the 1930's but I didn't know any went to Canada. The editor of Stationary Engine magazine here in the UK has one and also has the manufacturers records for them if you can find a serial no.
Philip
The Following User Says Thank You to Philipagri For This Post:
Old 10-13-2018, 12:00:39 PM
francois85 francois85 is offline
Bonjour les amis
Here is a Ransomes Wizard sold in France.
Bien amicalement
François
The Following 5 Users Say Thank You to francois85 For This Post:
Old 10-13-2018, 11:00:05 PM
Nathan K. Nathan K. is offline
Neat engine, I wonder if the subbase is buried under it?!. Might want to do some digging-maybe the oiler and other parts are there.
Nathan.
Old 10-14-2018, 12:23:31 AM
I'm sure I've seen one of these engines before, here in Australia, although I didn't take much notice of it. From my little bit of research today, they seem to be an interesting engine. According to this link, there are only 10 known; I didn't realise they were that rare. They are said to be a two-stroke, yet there is clearly a valve in the head? and they are a compression-ignition engine, although they don't run on diesel, but petrol-paraffin? No spark ignition, but fuel injection? which all makes for a fascinating engine to get running.
https://www.gasenginemagazine.com/co...ansomes-wizard
Old 10-14-2018, 12:40:02 AM
Merv C Merv C is offline
A friend was looking at buying one not long ago. I don't know if he got it. Again I don't know if it is the same engine and I don't know its background.
I understand it is a two stroke hot bulb , Similar to the Tangey and Petter type. I can find out.
Merv.
The Following User Says Thank You to Merv C For This Post:
Old 10-14-2018, 02:33:17 PM
Bert Juffer's Avatar
Bert Juffer Bert Juffer is offline
Not Hotbulb , it uses the spray cup like the Hvid engines
The Following User Says Thank You to Bert Juffer For This Post:
Old 10-14-2018, 04:37:28 PM
That makes sense, what I'm looking at is actually the injector and not a valve.
Old 10-17-2018, 05:04:10 AM
You are right Bert. I have checked with my friend about the one he acquired.
This one is a 3hp and he tells me there is a 6hp runner that showed up at a rally last year.
Merv
Old 10-20-2018, 11:31:15 PM
Robt.'s Avatar
Thank you to all who replied! Francois85 Merci beaucoup pour cette illustration très intéressante. Si possible pourrais-je obtenir de vous une image haute résolution de cette illustration?
This must be a Ransome's Wizard as you all say and must be the 7hp model from the diameter of the piston which is about 5"; the stroke must be at least that much also. Flywheels are 30" diameter and 4" across the rim.
We have got the engine out of the bushes and into a secure location. While it had been where it was for some years, that was not where it was found or used originally.
No sub-base found unfortunately and I don't think it it ever made it to the location where the engine was latterly, as from the rust it appears to have been separated from the base long, long ago and perhaps there never was a sub-base. Other than the loss of the engine tags, lubricator and a cover plate, it appears to be very complete and potentially restorable.
Unfortunately no information on the history of this particular engine has surfaced yet. The eccentric which drives the injector and oiler fractured at some point and that appears to be what caused the engine to be abandoned.
I'm gong to make up a temporary steel dolly so it can be moved around more easily and we'll see about getting it prepared for possible restoration in future.
If anyone one has more illustrations of photos, especially of the missing parts, those would be much appreciated.
ID:	321220   Click image for larger version
Brass Unknown Carburetor, Curved Flange RustySteele Carburetors, Mixers, Fuel Pumps and fuel delivery 0 06-18-2017 08:09:45 AM
Self Propelled Single Cylinder Upright - What Engine? Mike Paul Antique Engine Photos 5 12-10-2016 11:27:11 AM
unknown single cylinder pipefitter72 Unidentified Engines 9 09-22-2015 02:12:12 PM
Curved Spoke Flywheels and Single Rivet Laps Steamrguy Steam Stationary Engines, Traction Engines, Steam Boats 15 04-12-2012 09:30:19 AM
