Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Unidentified Engines Post your photos and questions about your unknown engine and look for answers here.
Unknown hit and miss engine
this thread has 6 replies and has been viewed 665 times
Old 10-15-2018, 11:04:40 AM
ryan214 ryan214 is offline
Default Unknown hit and miss engine
Hello everyone, I am new to the forum and I joined because I recently picked up a hit and miss engine as apart of a package deal of my main hobby- John Deere garden tractors. I know almost nothing about them and need some help. As far as I can tell, I am missing the piston and rod, ignition system, and maybe the governor if it has one. My first step is asking for you to help me identify what make and model this is. I was told it is a 1.5 hp and based on the markings I would assume it is a International Harvester engine. I would really like to get the parts for this and get it running if it can be done for under $100. I am a college student so funds on a toy like this are not very big. Any help is greatly appreciated with identification, parts suppliers, and any other words of wisdom you may have.
Thanks,
Ryan
ID:	320871   Click image for larger version
ID:	320872   Click image for larger version
ID:	320873   Click image for larger version
Old 10-15-2018, 01:49:15 PM
Default Re: Unknown hit and miss engine
Your engine appears to be an IHC 'M' 11/2 HP engine. Gasoline only carb - mixer. There should be a tag on top of the hopper. The engine should be painted green. it uses a WICO EK magneto, so it looks like it was built after 1923. The mag mounts on the vertical post behind the flywheel with 2 bolts. Without the tag, virtually impossible to date exactly, as that is the only place they put the engine serial number.
NOTE: The M is a throttle governed engine! Nice runners, and a good display engine.
Old 10-15-2018, 02:12:10 PM
jbo.aermotor jbo.aermotor is offline
Thanks,
Ryan
Ryan, Hit and miss Enterprises has a good supply of new & used parts.[COLOR="Silver"]
[SIZE=1]---------- Post added at 11:05:17 AM ---------- Previous post was at 11:01:58 AM ----------[/SIZ
---------- Post added at 11:12:10 AM ---------- Previous post was at 11:05:17 AM ----------
Ryan,hit & miss enterprises has a good supply of new and used parts.
Old 10-15-2018, 02:21:05 PM
Thank you for the information! Unfortunately it appears that I won't be able to fix this up for anywhere near what I want to spend. Now the question is, is what I have worth anything, or is it better off getting sold as a piece of yard art?
Ryan
Old 10-15-2018, 03:36:24 PM
turbo's Avatar
turbo turbo is offline
I would say judging by the missing parts. $75-100
Old 10-15-2018, 03:43:04 PM
kwfiggatt kwfiggatt is offline
What is the main problem with it - missing mag? Does it turn over and have compression?
You could always rig it up to run on a battery and coil, if funds are tight. It looks pretty complete to me, except for the mag. Some creative bracket making, a micro switch, a trip finger, and a coil and I think you'd be making smoke...
That one looks way too nice for yard art...
Kevin
Old 10-15-2018, 03:52:12 PM
The main problem is it doesn't have a piston, ignition system, or throttle governor, and maybe a few other missing pieces. From some quick parts searches I would be looking at an estimate of $500 to complete it and get it going. I think this one will be getting sold as it isn't practical for me to fund a project that would get used once or twice a year at shows. If anyone is interested in it shoot me a PM
Ryan
Unknown Hit and Miss Engine Merv C Unidentified Engines 13 03-31-2018 08:53:05 AM
Unknown hit miss engine Emu3hp Antique Gas Engine Discussion 4 09-19-2016 09:19:24 PM
Hit and Miss engine, unknown make. terrywerm Unidentified Engines 10 05-30-2016 08:11:45 AM
Unknown Hit & Miss Engine kdchester Unidentified Engines 5 02-04-2010 10:49:00 AM
Unknown Hit Miss engine Plus 3 others Wildcat Unidentified Engines 6 04-14-2009 09:26:49 PM
