Magnet Charger
this thread has 12 replies and has been viewed 1583 times
Old 10-21-2018, 11:04:08 AM
Chuck Hall Chuck Hall is offline
Default Magnet Charger
I just bought an antique magnet charger and need help on operating the charger. First I have a Sumter #12 magneto for a Fairbanks Morse ignitor engine I would like to charge the magnet on. The charger has a knife switch on it and cables to hook to possibly a 12v battery? and marked N & S on the poles. I also have a liquid filled car compass. Where do I go from there? The mag is still on the engine. Thanks, Chuck
Old 10-21-2018, 01:31:43 PM
Default Re: Magnet Charger
Instructions for the magnet charger. You need a magnet charger , a compass , A set of soft iron bars shaped to sit on the charger and up , over , and into and touching the magnets in the flywheel with as large an area as you can get (at least the size of the end of the magnet). A compass is a north seeking instrument , it will point to the north pole. KEEP THE COMPASS 2 TO 3 FEET FROM THE MAGNET AND THE CHARGER. Connect your auto battery (6 or 12 volt) to the charger and MARK the charger terminals with a + and a-. Turn on the charger and with the compass determine the North and South pole of the charger and MARK THEM. With everything marked , you will be able to hook them up the same every time. Using the compass determine the north and south of the magnet that is to be charged. MARK THEM. Magnets charge opposite to the charging source. Place the north of the magnet on the south pole of the charger. And the south pole of magnet on the north of the charger. Close the switch for about 5 seconds then open. Do this 4 or 5 times. Ron
The Following 4 Users Say Thank You to Ronald E. McClellan For This Post:
Old 10-23-2018, 07:58:08 PM
I don't quite understand the soft iron bars up, over, into and touching the magnets in the flywheel?
Old 10-23-2018, 09:29:50 PM
This was written to address magnets in a flywheel , like a Maytag. Depending on how your magneto is made you may need soft iron bars to come into contact with the magnets. You need direct solid contact to the magnets. Ron
The Following User Says Thank You to Ronald E. McClellan For This Post:
Old 10-24-2018, 07:43:27 PM
cobbadog cobbadog is offline
Sometimes when I come across something that does not quite register properly I do a YouTube search, this quite often helps a lot in the understanding the "how to" department.
Old 10-24-2018, 07:57:59 PM
My Mag is Not in the flywheels. It is a Sumter rotary magneto #12 for a 1916 Fairbanks Morse igniter fired 3hp throttle goverened engine. I took the mag off the engine with the gear and base still attached. It seems to me that the mag wants to line up with the magnet charger as N to N and S to S as N on the mag to N on the charger. But was told to put S on the mag to N on the charger, and N on the mag to S on the charger, but it seems to fight it that way so I stopped. I do not have any metal shims. I need more tutering.
Old 10-25-2018, 09:46:37 AM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
Images: 14
You can also dangle a magnet on a string over the charger and it will
line up the right way.
Old 10-25-2018, 10:58:13 AM
I have no idea what you are doing! N to N -- S to S will repel Not attract. Check your compass to make sure its polarity hasn't been reversed. Ron
Old 10-25-2018, 08:20:25 PM
A friend gave me on old magnet for a John Deere E 1 1/2 hp to play with. It has a N insignia on one side, so I'm assuming it is North. It seems like a good magnet, it sticks to stuff. I tried it on my magnet charger and the N on the magnet went for the N on the charger. I tried the string test, sure enough, the magnet went for the N. When the magnet latched onto the charger, it wouldn't let go. I had to force the magnet off the charger. I tried holding the N on the magnet to the S on the charger but wouldn't go, so I decided to quit till I figure something out. Also the poles on the charger was heating up. I'm using a 12v battery. Another thing, I'm not sure about my compass indication. Seems like it wants to go wacky.?
Old 10-25-2018, 10:22:52 PM
edisondiamond edisondiamond is offline
Magnets can get their polarity changed. Just because it is marked "N" maybe at some point it got recharged wrong.
The Following User Says Thank You to edisondiamond For This Post:
Old 10-26-2018, 12:44:57 AM
Possibly the best thing to do is use a compass and confirm the polarity first. As suggested the magnet may have been reversed in an earlier life OR the posts on the charger may have been identified wrongly.
Get a compass and confirm everything first, then mark it up as to what it reads with a marking pen and that way you can then proceed in the right "direction".
(pun intended).
Hopefully this will help you out. Let us know how you get on.
Old 11-11-2018, 10:04:43 PM
flamingibis flamingibis is offline
Would it be heating up because it is a 6volt charger and not 12V? If it is an antique charger wouldn't it be more common to be 6volt?
Old 11-12-2018, 10:48:15 AM
You seam to be lacking on how a compass works. Take it outside and see if it points north. A compass points north because the needle marked north is actually charged south (opposites attract). Take your magnet outside and hang it on a string. It will come to rest in a north/south position. The side that is pointing to the north is the south pole of the magnet. Mark it! Then start over with the charger. The charger is getting hot because you are leaving it on too long. It is only meant to be used a few seconds at a time. 6 or 12 V is OK It is the amps that does the job. Ron
Magnet Charger JasonEhlersv45 Farm + Industrial Antiques and Collectibles 5 01-13-2012 04:02:18 PM
Magnet Charger MedicHamilton Antique Gas Engine Discussion 5 07-23-2011 03:23:10 PM
Magnet charger Steve Kreiner Antique Gas Engine Discussion 1 07-30-2010 06:16:24 PM
Magnet charger Mark K Antique Gas Engine Discussion 4 03-20-2005 10:27:46 PM
Magnet Charger Bill Miller Antique Engine Archives 5 03-06-2002 05:21:25 PM
