Fairbanks morse Z engine 475rpm #hp.??
this thread has 2 replies and has been viewed 541 times
Old 10-26-2018, 08:00:52 PM
bigweldsteve bigweldsteve is offline
Default Fairbanks morse Z engine 475rpm #hp.??
fairbanks morse z serial # 605047 475 rpm I found some online pictures but they do not match this engine. Magneto sets towards rear of water tank. Any help with id would be appreciated. thanks steve hand
Old 10-26-2018, 09:36:45 PM
ScooterBob ScooterBob is offline
Default Re: Fairbanks morse Z engine 475rpm #hp.??
according to the serial number list found here...
http://www.oldengine.org/members/may...s/fmserial.htm
it was built in 1925.
Posting a picture or two would help a lot, if you don't know how, instructions can be found here...
https://www.smokstak.com/forum/showthread.php?t=40589
Old 11-06-2018, 05:08:43 PM
Pictures would help. At 475 RPM, I would guess at a 6 HP. If you can't get pix, flywheel diameter would help. I am guessing a rotary mag mounted on top of the governor/cam mount, correct? Type R F/M mag?
10 H.P. Fairbanks Morse gas engine Gary Bahre Antique Gas Engine Discussion 6 02-19-2017 11:00:07 PM
Fairbanks Morse 15 hp Y Oil Engine smokinhot Vintage Diesel and Oil Engines 7 12-16-2016 11:14:15 PM
Fairbanks Morse engine Heins Vintage Diesel and Oil Engines 23 03-13-2012 10:09:37 AM
Fairbanks Morse 1B/5 Engine sammydeere Small Air Cooled Gasoline Engines 2 04-25-2011 02:48:44 PM
Fairbanks Morse engine Alex F Antique Engine Archives 2 12-12-2004 01:32:49 AM
