Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Unidentified Engines Post your photos and questions about your unknown engine and look for answers here.
Unknown Wisconsin single cylinder
this thread has 7 replies and has been viewed 723 times
Old 11-09-2018, 10:24:54 AM
A9lewis A9lewis is offline
Default Unknown Wisconsin single cylinder
Help me identify the engine I came across. It is a very large single cylinder Wisconsin engine with an attached hand clutch on the output side. I am told it was purchased at auction in the 1950's and used on a farm grain elevator. It has a 3 1/2 inch bore and 4 inch stroke. No tag but the four screws indicate it was a large tag. The head is aluminum casting AB102A. It uses a hand crank. Has oil bath air cleaner, zenith carb, wico magneto. It had been sitting in a barn probably a decade or more. It turned freely by the exhaust valve was stuck big time. 18 mm sparkplug but threads stripped out. I have been able to resurrect it and get it running. Don't know what to do with it though.
If you can give me the model number, year, and horsepower I would greatly appreciated it.
Al
Old 11-09-2018, 10:30:59 AM
Junkologist's Avatar
Images: 160
Default Re: Unknown Wisconsin single cylinder
Sounds like you have an AHH model.
Mike
SmokStak member #146
Old 11-09-2018, 10:54:47 AM
I think? the AHH is 3-5/8" bore, It may be the one just smaller in bore than the AHH
Old 11-09-2018, 11:00:41 AM
radiodoc radiodoc is offline
The Wisconsin AHH uses part number AB82 for the head. I think the AB102A is on a AGN or AGND. I'm sure if I am wrong someone will correct me on this. Allie
Old 11-09-2018, 11:50:07 AM
K-Tron K-Tron is offline
The AHH has a 3-5/8" bore, the AGH has 3-1/2" bore. However the engine that A9lewis is describing is an AGND. The AGND is a 12.5hp engine at 3200rpm. It first came out around 1957-1958. I believe it is the finest single cylinder engine Wisconsin made. It will run day in and day out under full load without missing a beat. With a Twin Disc over center clutch you have a pretty desirable engine. The AGND's were used on all sorts of industrial machinery for ~25 years.
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 11-09-2018, 01:00:58 PM
Thanks. I need to visit with the guy whose family had the longest. I was thinking it must have been made in the 40's.
Old 11-09-2018, 02:36:12 PM
Images: 160
Yep, you guys are right about the AHH bore. I think my mind is slipping.
Mike
Old 11-10-2018, 10:00:32 AM
The exhaust valve spring in this engine was a compound wound spring. Close wound at the top and loose wound at the bottom. I thought it was collapsed but it had sufficient pressure to work. I saw pictures of springs like it. Anyone know if this is the correct spring and why would they design something like that?
Onan unknown single cylinder tharlach Onan Generators 5 09-22-2016 08:01:59 PM
Stromberg ML 16 for Wisconsin Single cylinder TractorDom Carburetors, Mixers, Fuel Pumps and fuel delivery 0 11-15-2015 10:15:16 PM
unknown single cylinder pipefitter72 Unidentified Engines 9 09-22-2015 02:12:12 PM
Large Single Cylinder Wisconsin John Schwiebert Wisconsin Engines 12 04-11-2009 08:39:17 AM
Unknown Single Cylinder Marine Engine Andrew Walker Antique Marine Engines and Outboard Motors 0 02-24-2009 01:55:10 PM
