witte 3hp hit and miss
this thread has 3 replies and has been viewed 544 times
Old 11-09-2018, 06:33:57 PM
315center 315center is offline
Default witte 3hp hit and miss
I just picked up a witte 3hp hit and miss engine. I am missing the magneto and magneto mounting bracket. Does anyone have this bracket or know if the bracket from a witte 2hp hit and miss is the same?
Old 11-09-2018, 08:30:07 PM
wagswitte wagswitte is offline
Default Re: witte 3hp hit and miss
Most Wittes are throttle governed engines unless itís a headless post some pictures if you can of what you have.
Old 11-10-2018, 10:49:54 AM
Pics of witte 3hp hit and miss also missing the follower assembly that the pushrod rides on and the rod and springs for the magneto trip
ID:	322523   Click image for larger version
ID:	322524   Click image for larger version
The Following User Says Thank You to 315center For This Post:
Old 11-11-2018, 01:09:14 AM
Doug Oldenburg's Avatar
Doug Oldenburg Doug Oldenburg is offline
Throttle governed......Not a Hit N Miss. Not sure if the items you need will interchange.
"So Much Iron & So Little Money"
Witte B Hit and Miss Engine ScooterBob Antique Gas Engine Discussion 9 05-21-2017 05:20:43 PM
Witte Hit & Miss Engine 1/2 H.P gaspower Antique Gas Engine Discussion 8 06-14-2013 10:52:26 AM
3 hp Witte hit and miss JohnCCarlson Antique Gas Engine Discussion 11 08-17-2012 03:29:52 PM
Witte 2 1/2 hp Hit and Miss courtnhayd Antique Gas Engine Discussion 0 07-27-2012 05:50:08 PM
Headless Witte hit & miss governed W.P.Klein Antique Gas Engine Discussion 3 07-03-2006 09:48:07 AM
