GM Diesel identification help
this thread has 5 replies and has been viewed 551 times
Old 11-13-2018, 09:41:01 AM
docgartner docgartner is offline
Photo GM Diesel identification help
I am looking to identify this engine. It is the power plant for the hydraulic pump on a vintage rail crane. The radiator is stamped Detroit Diesel, but the engine has a raised logo for GM Diesel Motors.
Any help and guidance is much appreciated, including redirection within this forum or to other outside groups.
Seth Gartner
Charlotte, NC
Name:	GM diesel1.jpg
ID:	322790   Click image for larger version
Old 11-13-2018, 09:45:47 AM
Heins Heins is offline
Default Re: GM Diesel identification help
I would guess it would be a 2-53 Detroit.
Old 11-13-2018, 10:37:04 AM
ronm ronm is offline
Yes, a 2-53.
Smokstak member #442
Old 11-13-2018, 11:54:36 AM
GADavis GADavis is offline
Were not Gm and Detroit the same many years ago?
The Following User Says Thank You to GADavis For This Post:
Old 11-13-2018, 12:08:15 PM
Norm W Norm W is offline
GM Diesel became Detroit Diesel in 1965. If it says GM that tells you something about the age. The serial number would tell you more.
The Following User Says Thank You to Norm W For This Post:
Old 11-13-2018, 12:42:55 PM
The Diesel Doctor The Diesel Doctor is offline
The model and S/N are stamped in the block behind the secondary fuel filter. AL
The Following User Says Thank You to The Diesel Doctor For This Post:
Lister Diesel Identification Help lauryy Vintage Diesel and Oil Engines 5 03-27-2017 04:44:13 PM
Onan 2 cyl marine diesel identification Island Man Onan Generators 8 03-04-2014 01:00:05 PM
Diesel Engine Identification ? Glenn Ayers Vintage Diesel and Oil Engines 5 07-06-2013 08:53:48 PM
Lister diesel identification? crunchiespg Vintage Diesel and Oil Engines 4 03-27-2013 09:14:37 PM
Old 45KW Diesel Identification kevink1955 Onan Generators 4 05-07-2010 06:31:49 PM
