Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Unidentified Engines Post your photos and questions about your unknown engine and look for answers here.
Unknown Engine / Generator
this thread has 4 replies and has been viewed 608 times
Old 11-13-2018, 12:19:37 PM
High Voltage High Voltage is offline
Default Unknown Engine / Generator
Does anyone recognize this old girl? No tags, markings or numbers that i can see. Any info would be great! Thanks.
ID:	322806   Click image for larger version
ID:	322807   Click image for larger version
ID:	322808   Click image for larger version
Old 11-13-2018, 12:52:55 PM
David Babcock David Babcock is offline
Default Re: Unknown Engine / Generator
Homelite. Probably military. Db.
Old 11-13-2018, 01:42:27 PM
Vanman Vanman is offline
Yes, Homelite. Those are neat! Very high quality. But I have never seen one with a four pole generator before. Very interesting. Would be interesting to see under the brush cover, to see if it is AC or DC.
Old 11-13-2018, 01:49:46 PM
Exclamation Re: Unknown Engine / Generator
Homelite definitely - military, not so sure. I see the muffler is not mounted. Do NOT run with open exhaust, you will burn the piston in a hurry if you do. What kind of shape is it in? These are screamers - 3600 RPM. I have seen them in 110 VDC, 115 VAC and 220 VAC versions. If you try to run, check out the flywheel and governor for movement. The governor is inside the flywheel mount assembly, and it tends to wear the bearings out. The governor acts as a throttle to the intake charge. When the bearings go bad, it allows the magnets in the flywheel to hit the magneto core, either magnetizing it or breaking it off its mount. The seals can go bad too. Not many parts left for these old units. Mcmaster-Carr may have bearings, and NAPA might be able to match up a seal. You might be able to get rings from sponsors here on the Stak.
Old 11-14-2018, 08:47:53 PM
Thanks! Great info. It looks to be complete, but it's seized and the manifold is cracked. Neat old engine though.
Unknown engine with a Wico generator? taaviw126 Small Air Cooled Gasoline Engines 2 08-27-2017 04:48:27 AM
Unknown Generator and Engine Early Iron Generators & Electric Motors General Discussion 5 05-27-2016 07:39:20 PM
unknown engine/generator Scotty 2 Unidentified Engines 0 05-02-2014 04:57:09 AM
Unknown Generator - Lauson RAY Engine John Newman, Jr. Generators & Electric Motors General Discussion 0 06-20-2011 12:58:29 PM
Unknown engine-old 25kW ONAN generator set Jim Rankin Antique Autos and Trucks 0 04-28-2008 02:54:01 PM
