Can you i.d this old water cooled 2 cylinder diesel attached to a winco generator
this thread has 12 replies and has been viewed 1187 times
Old 11-16-2018, 05:56:53 PM
YellowLister YellowLister is online now
Default Can you i.d this old water cooled 2 cylinder diesel attached to a winco generator
I got lucky, and found this old girl on the local cl for a really good price.. which doesn't happen often here..
Should say winpower generator
I have looked and looked and can not find anything that resembles it..
Any help or tips would be greatly appreciated as I would love to be able to find parts..
I got it running after changing all the fluids and filters
Has a Simms injection pump. No name at all on the engine, just a few numbers
ID:	323006   Click image for larger version
ID:	323007   Click image for larger version
ID:	323008   Click image for larger version
The Following 3 Users Say Thank You to YellowLister For This Post:
Old 11-16-2018, 05:58:45 PM
Default Re: Can you i.d this old water cooled 2 cylinder diesel attached to a winco generator
Few more pics
ID:	323010   Click image for larger version
ID:	323011   Click image for larger version
ID:	323012   Click image for larger version
Old 11-17-2018, 09:28:35 AM
Billy J Shafer's Avatar
It looks like a Dorset Engine. English part of Ford at one time.
Old 11-17-2018, 10:03:35 AM
ronm ronm is offline
Thanks, Billy. I was thinking it resembled 1/2 of a Fordson Major engine...
Smokstak member #442
Old 11-17-2018, 11:33:51 AM
OrgWayne OrgWayne is offline
OK , Whats the Motor cycle sticking its rear end in your 3rd pic ?
So if you where still on the left coast, would u be near the fires ?, I think u where south of them right
Wayne
Old 11-17-2018, 11:37:52 AM
Another choice it could be a Perkins. Another rare chance it could be a Gardner but the starter looks wrong. I have only seen two Gardner engines in the states. I would guess Dorset or Perkins.
Old 11-17-2018, 11:58:05 AM
The old house was in Granada hills in the San Fernando valley so very close to the fires but all we would of got was smoke..
I looked up dorset and cannot find any 2 cylinder versions just 4..
Will look up gardner.. I thought perkins because of the fuel filter but no luck finding one like it.
The motorcycle is a Honda 74 I think.. I made a electric box under the seat and the seat mount for a buddy
ID:	323048   Click image for larger version
ID:	323049   Click image for larger version
Old 11-17-2018, 01:33:44 PM
Heins Heins is online now
Any Perkins I have seen uses a CAV pump, I an trying to think what engines uses a Simms pump besides Ford.
Does the two cylinder fires evenly or does it fire both cylinders during the same revolution of the crank and none of them fires the next revolution like a two cylinder John Deere?
Old 11-17-2018, 02:59:52 PM
AlanR AlanR is offline
As far as I can tell, the engine is an ALBIN AD-21.
http://www.albinmotor.com/AlbinMotor.../res-ad21.html
The Following 3 Users Say Thank You to AlanR For This Post:
Old 11-17-2018, 04:29:47 PM
Sooty Jim Sooty Jim is offline
Alan... you da MAN! That's a rabbit-outta-the-hat!
Old 11-17-2018, 04:43:25 PM
That sure looks like a winner! Thanks very much!
Old 11-18-2018, 12:28:06 AM
K-Tron K-Tron is offline
There was a generator like this listed in upstate NY last summer for around $800. I was tempted to drive the three hours to look at it, but I wasn't sure what the engine was. It did not look like anything I had seen before. Let us know how that Albin runs and works out.
Chris
Old 11-18-2018, 08:01:48 AM
Its runs great, but someone hooked some wires up wrong and I'm getting a.c voltage at the battery, need to dig around in the generator and fix it before running it for more than a minute
Lister 4 Cylinder Water Cooled Diesel - can you identify the model? chrisowens Vintage Diesel and Oil Engines 8 11-19-2017 04:22:05 AM
4-cylinder Radial - water cooled diesel? DanG Unidentified Engines 33 01-02-2015 11:39:48 AM
generator ID help - Onan 6.0 twin cylinder - air cooled diesel TxTooTall Onan Generators 14 05-20-2014 08:31:32 PM
White Two Cylinder Water Cooled Diesel Robin Ray Vintage Diesel and Oil Engines 19 08-22-2012 02:11:06 PM
4-cylinder Radial - water cooled diesel? Craig A Vintage Diesel and Oil Engines 0 01-14-2011 11:35:41 PM
