Magnetos, Ignition Coils and Spark Plugs Discussion about magnetos, buzz coils, spark plugs, ignitors and low tension coils. |
Bosch DU 4/2 - - intermittent spark on one circuitthis thread has 7 replies and has been viewed 478 times
Hey guys -
The Bosch DU4/2 magneto on my Rumely had some spark issues. Removed it from the tractor and cleaned the points, removed the distributor block & cleaned that and the 'spark rod' that that comes thru the center of the mag. Have attached a stiff wire to each of the 2 spark plug wire terminals and bent them around to the housing with about a 3/16 to 1/4" gap. Made an attachment for my cordless drill to drive the thing to test. I'm getting a good blue spark on both circuits, but the second one that fires in the sequence only fires about 50% of the time. This is true for running with the impulse tripping or faster than impulse speed. What should I be looking at that might be causing the second terminal to only fire intermittently ? Thanx ! Pete |
Sponsored Links |
Sometimes for odd reasons the cams on the contact ring are shimmed to different heights and that causes the points to open a different amount and at a slightly different time. It is possible one set of points is not opening at the "sweet spot" of armature rotation to get the best spark.
Bud |
1/4" is a large gap for an old mag, you're stressing the insulation. If it fires 3/16" I would set the plug gaps .020 -025" and see how it does, the same coil is firing both plugs, look for leaks-cracks opens in cap, rotor, wires.
If the coils are good, 1/4" should not be a problem. I would look for carbon tracks or corrosion on the distributer cal and rotor. internal corrosion on the cap terminals increases resistance. You might have a look at the rotor and carbon brush, where the high voltage comes off the rotor. there might be a bit of carbon dust in the housing that would divert spark.
Weak magnets are also a possibility.
info@mcdonaldcarb.com |
![]() Quote:
Cheer Scott |
The Following User Says Thank You to Scotty 2 For This Post:
It was common for the magnetos to have a built in safety gap, this was a gap with a path to ground to prevent the mag from destroying itself if a plug wire came off while running. You may be at the point where the fire is jumping the safety gap at times. Close your gap a little and try it, you may not have a problem.
The Following 4 Users Say Thank You to J.B. Castagnos For This Post:
Hello all
All of the replies could lead to intermittent spark and worth checking. The safety gap is a far gap if this video is anything to go on. I love old magnetos. It seems to me that the older they are, the better they are. This one was found in the bottom of a bucket of rubbish at an auction. It's one that must of been made around the time of WWI. The Bosch had been machined out and Liberty stamped in. All I did to this one was a good clean and service and that was that. Cheers Scott |
The Following 2 Users Say Thank You to Scotty 2 For This Post:
Bookmarks |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | F o r u m | Replies | Last Post |
Kohler K301T intermittent spark and issue with points | nezwick | Small Air Cooled Gasoline Engines | 4 | 11-01-2018 11:31:29 AM |
Onan CCKB intermittent spark | phrankndonna | Onan Generators | 28 | 06-03-2012 04:06:10 AM |
Bosch Spark Plug | dirtycurt | Magnetos, Ignition Coils and Spark Plugs | 0 | 05-19-2011 12:31:30 AM |
Intermittent spark on Wico EK | Tom Jamboretz | Magnetos, Ignition Coils and Spark Plugs | 2 | 10-19-2010 02:15:13 PM |
B&S 5S - Intermittent Spark - Newbie Question | Gauge | Small Air Cooled Gasoline Engines | 15 | 11-22-2006 12:39:48 PM |
