Oil Field Engines
Clark & Norton half breed with a very interesting bed.
this thread has 1 replies and has been viewed 703 times
Old 12-01-2018, 03:17:16 PM
Brian Lynch's Avatar
Images: 23
Default Clark & Norton half breed with a very interesting bed.
I found this Clark & Norton conversion close to 20 years ago. I've been trying to buy it ever since then. I think the bed was made by Oil Well Supply. Maybe an Innis large mill style engine? I love that bored crosshead and dual flywheel look. The main bearing caps on this engine are massive compared to most half breeds. I know it's not a Bessemer bed, that's pretty obvious. I'm in contact with the owner quite frequently. It will now be a nightmare to get out of where it sits. Twenty yrs ago it would have been a lot easier!
ID:	323769   Click image for larger version
ID:	323770   Click image for larger version
ID:	323771   Click image for larger version
ID:	323772   Click image for larger version
ID:	323773   Click image for larger version
Old 12-05-2018, 12:22:41 AM
Bobwyatt Bobwyatt is offline
Default Re: Clark & Norton half breed with a very interesting bed.
The bed plate is definitely different for a half breed.. I have only seen 1 other halfbreed with the cross slide like that .. we have a Clark and norton on a struthers bed plate ...
A Clark & Norton 4 cycle sideshaft Brian Lynch Oil Field Engines & Related Equipment 0 10-17-2016 05:31:56 PM
half breed David A. Oil Field Engines & Related Equipment 2 01-27-2016 01:32:51 PM
Inside the Clark & Norton factory, 1905 Photo Brian Lynch Oil Field Engines & Related Equipment 1 09-19-2011 03:47:20 PM
Clark and Norton/Struthers Wells piston removal? Ray Ethridge Oil Field Engines & Related Equipment 14 11-12-2010 11:33:50 PM
clark norton/farrar and trefts woody bagwell Antique Engine Archives 5 10-31-2004 10:14:24 PM
