Old Witte regulator swap questions
this thread has 0 replies and has been viewed 362 times
Old 12-23-2018, 03:54:41 PM
ckhd ckhd is offline
Default Old Witte regulator swap questions
I have an old Witte with a Kato generator. It came from Mexico, so it was set at 120v/50 hz. The regulator is adjustable to allow the engine speed to be turned up to 60hz and then adjust the voltage back down to 120v.
The adjustment broke.
Being an ancient gen set, I haven't been able to find an exact replacement regulator.
I did find a similar regulator that is 120v/60hz. Will it work?
The first attachment is the original (sorry about quality, my phone isn't the best camera). The second is the new one.
Anyone know if it's compatible.
ID:	324994   Click image for larger version
Onan JB 7.5 Regulator 305-0688 time to swap? AndersonMillTexas Onan Generators 47 01-15-2018 12:58:52 PM
Witte Generator Voltage regulator otto Generators & Electric Motors General Discussion 26 06-02-2014 04:22:11 PM
Witte Generator Voltage Regulator BrianHaze Generators & Electric Motors General Discussion 3 06-26-2013 02:57:39 PM
Witte Generator Voltage regulator otto Vintage Diesel and Oil Engines 3 06-24-2013 10:42:32 AM
Witte Voltage Regulator bushm0nkey Oil Field Engines & Related Equipment 2 07-11-2006 03:50:55 AM
