B&S 2 spark mag
this thread has 3 replies and has been viewed 452 times
Old 12-28-2018, 06:17:13 PM
Andrew Mackey Andrew Mackey is online now
Question B&S 2 spark mag
I have a B&S 3 pole coil that was on a 5 HP aluminum block 5 HP engine. it was on a MOPECO heater/blower unit, built in the 1960s I do not have the engine, but would like to know if that mag is still available. One high tension lead went to the spark plug, the other went to the gas burner/heater ignition system Thanks,
Old 12-28-2018, 11:02:05 PM
cobbadog cobbadog is offline
Default Re: B&S 2 spark mag
Sorry about this silly question Andrew.
But would it be possible to jump another HT lead from the spark plug to run to the heater?
Old 12-29-2018, 03:09:09 PM
John Newman, Jr.'s Avatar
Trying to fire two plugs off of one high tension lead will probably not work. The plug in the engine will have more resistance due to the compression and the other plug will see all of the spark.
I think Craig DeShong has at least one Lauson engine that has dual HT leads on the coil for some kind of military heaters.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 02-19-2019, 05:04:51 PM
Cobbadog, John has it exactly right. You need both ends of the high tension side of the coil to get a twin spark. 2 ways to get it - either have twinned coils on a common armature , or as i noted 2 live ends of the high tension coil. B&S used the single coil, 2 lead out type. On later MOPECO heater/blowers, the company used a battery igniter for the burner. They also tried a piezio electric igniter, like those used in grills, but engine vibration destroyed the crystals pretty quickly, so they went back to the battery jobs. The coil I was looking for was mounted with 4 bolts - engines built back in the 1960s.
IHC H4 no spark DTurner Magnetos, Ignition Coils and Spark Plugs 1 03-04-2016 02:03:58 AM
Slick electro mdl 56 magneto on Continental FS162. Spark then no spark Greenbuggy Magnetos, Ignition Coils and Spark Plugs 2 06-29-2014 06:23:31 PM
Briggs WMB Spark at Wire but Can't See Spark at Plug KubotaDiesel Small Air Cooled Gasoline Engines 15 05-05-2014 11:15:05 AM
No Spark on my 15.0 JC Dave_T Onan Generators 14 02-04-2009 07:54:47 AM
Why doesn't the spark-spark? flasks Magnetos, Ignition Coils and Spark Plugs 4 01-02-2009 01:49:20 AM
