Cushman model C Correct Spark plug?
this thread has 3 replies and has been viewed 283 times
Old 01-13-2019, 02:20:28 PM
Sch1983 Sch1983 is offline
Default Cushman model C Correct Spark plug?
Hi everyone. I got an old model C 4Hp cushman engine. Could someone please tell me the correct type of spark plug and the part number? thanks
Old 01-14-2019, 11:11:40 AM
Ret AF Ret AF is offline
Default Re: Cushman model C Correct Spark plug??
I own two Cushman Binder 4hp engines. Both have AutoLite spark plugs - the numbers are F11 on one engine and 3095 on the other.
---------- Post added at 10:11:40 AM ---------- Previous post was at 10:00:14 AM ----------
I forgot to add that I'm not sure that these spark plugs are the correct types, but the engines seem to run well with them. Hit and Miss enterprises has them for sale for $5.50 item number HM02.
Old 01-14-2019, 11:54:51 PM
Talking Re: Cushman model C Correct Spark plug??
f-8 or f-10 champion, should work used on many old small engines,f-11 seams alittle hot unless burning a lot of oil, check for clearance to piston first..
Old 01-15-2019, 01:33:48 PM
The Cushman C ("binder") engine uses a plug with ˝" pipe thread. The F-series Champion plugs, I believe, are 18mm and will not fit.
The Following User Says Thank You to Kirk Taylor For This Post:
Cushman model 45 10hp eng#242 spark plug Anvilfarms Antique Gas Engine Discussion 6 10-29-2015 10:15:41 AM
F&J correct spark plug? Duane H Magnetos, Ignition Coils and Spark Plugs 0 08-18-2012 04:36:41 PM
Correct spark plug Joseph Onan Generators 0 11-07-2008 08:49:47 PM
Correct spark plug jeff Magnetos, Ignition Coils and Spark Plugs 2 10-20-2008 08:25:05 PM
Correct Spark plug for Cushman? Chris Hibshman Antique Gas Engine Discussion 2 08-09-2007 07:06:57 PM
