Austrian make of mag?
this thread has 3 replies and has been viewed 256 times
Old 01-16-2019, 08:46:05 PM
mechman mechman is offline
Default Austrian make of mag?
Got the mag off the early ported exhaust German air cooled gen set --see it in the gen set forum--the make is A U other info is # A1 & 12364 stamped into side base --on the brass cover over the points is Stamped AUS--Austria?? any help appreciated It seems complete & in decent condition
The Following User Says Thank You to mechman For This Post:
Old 01-16-2019, 11:18:31 PM
cobbadog cobbadog is offline
Default Re: Austrian make of mag?
Are you sure it is not a BOSCH mageto?
Old 01-18-2019, 01:04:37 PM
Goodday To look at it it does look similar to a bosch, however it had Au cast into the top inside of the body, as well as Au on the side plate--thanks Larry
Old 01-18-2019, 11:51:03 PM
I think you will find that the "AU" is a model number not country of origin.
What make is this? 6ary Generators & Electric Motors General Discussion 5 05-14-2012 10:13:11 PM
What Make? Christophe35 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 02-27-2012 12:17:01 AM
What make is this one? Rusty Engines Smokstak Down Under 5 09-06-2009 11:21:37 PM
Austrian Steam Adventure Colt Edin Steam Stationary Engines, Traction Engines, Steam Boats 1 10-05-2005 11:24:58 PM
what make is this mag? lauren langdon Antique Engine Archives 6 05-20-2004 06:38:02 PM
