Magneto Timing 1 hp Mogul
this thread has 3 replies and has been viewed 1672 times
Old 11-09-2006, 09:27:14 PM
oldironcollector's Avatar
oldironcollector oldironcollector is offline
Default Magneto Timing 1 hp Mogul
Is there any method to the madness or does it matter where the gears fall on the 1 hp Moguls ? I see no marks and of course the magneto is a rotary low tension.
Thanks for any help on this one!!
Denny
Old 11-09-2006, 11:05:10 PM
Ken Majeski's Avatar
Images: 46
Default Re: Magneto Timing 1 hp Mogul
Yes it Does Matter... And it Matters a Lot.... The magneto has to be timed to the igniter. The igniter has to trip at peak voltage. Look on the end of the mag opposite the gear and see if there are lines on the bearing plate and the shaft. The line on the shaft should line up with the second one on the bearing when the engine is turned the way it runs. One mark on the bearing is for clockwise rotation and the other for anticlockwise rotation....
Ken Majeski, Ellsworth Wis.
Old 11-09-2006, 11:10:09 PM
So, the correct method would be to locate these marks and set the flywheel ignite line even with the mark on the crankcase while aligning the mark on the mag shaft with the mark on the bearing?
Thanks for your help.
Denny
Old 11-10-2006, 12:03:17 AM
Images: 46
Yup.... Igniter should trip, Marks should line up, All at the same time.... You may be limeted due to the teeth on the gears but get it as close as you can.... You may have to change the igniter a little to Jive with the marks...
I have a 1 Hp Mogul and I don't have a crank for it and it starts just by giving the flywheels a quick flip...
1 HP Mogul Magneto Roger Eldred Antique Gas Engine Discussion 3 07-08-2007 09:50:18 PM
1 HP Mogul Magneto TomT Antique Gas Engine Discussion 3 05-18-2007 09:44:11 PM
One Last Plea - 1HP Mogul Timing Greg Ledger Antique Engine Archives 4 06-21-2004 10:17:07 AM
1 hp Mogul timing Papa Al Thrasher Antique Engine Archives 1 08-30-2002 04:56:29 AM
Mogul 1 HP Timing Mike Antique Engine Archives 0 11-21-1999 11:27:57 PM
