1 HP Mogul Magneto
this thread has 3 replies and has been viewed 1330 times
Old 07-08-2007, 08:58:19 AM
Roger Eldred's Avatar
Roger Eldred Roger Eldred is offline
Question 1 HP Mogul Magneto
Will try this again. On the lead out on the magneto, there is a contact between the armature and the lead out, what should be used? carbon? Thanks for your input.
Roger
Old 07-08-2007, 07:05:27 PM
Tilinghast Tilinghast is offline
Images: 2
Default Re: 1 HP Mogul Magneto
Roger...On most of those types of mags they did in fact have a carbon connection between the armature and the lead out. I have seen a couple that were broken when someone pulled the armature out without removing the lead out tower and carbon connection first. They run in a grooved area that looks a little like a v-groove pulley.
Dave.
Old 07-08-2007, 07:43:59 PM
Roger
Take an old C size flashlight battery and open it up and use the carbon stick in the center to fashion a new contact which simply ( in most cases) fits into the end of the spring. Hope this will solve the problem Joe Morris
Old 07-08-2007, 09:50:18 PM
Edd Payne Edd Payne is offline
Carbon is fine but the original brush in the low tension L & R mags was a woven bronze type material .This is better than carbon as it tends to self clean where as carbon tends to leave a deposit on the collector ring and needs to be cleaned from time to time.Any failures with these mags usualy comes down to a carbon brush that has been fitted and fails to make contact.I use both with OK results but prefer to use the original if possible.
1 HP Mogul Magneto TomT Antique Gas Engine Discussion 3 05-18-2007 09:44:11 PM
Magneto Timing 1 hp Mogul oldironcollector Antique Gas Engine Discussion 3 11-10-2006 12:03:17 AM
What the difference between a Mogul and Mogul Jr?? Adam Cottrill Antique Engine Archives 2 12-31-2002 09:47:36 PM
Help! on Mogul james Antique Engine Archives 0 03-17-2002 10:36:43 AM
Missing MOGUL Magneto Paul Spence Antique Engine Archives 2 10-13-2000 12:44:41 PM
