1HP Mogul Magneto and Gear
this thread has 3 replies and has been viewed 1614 times
Old 11-03-2008, 11:17:36 AM
Mike's Avatar
Mike Mike is offline
Images: 1
Default 1HP Mogul Magneto and Gear
Just purchased a 1HP Mogul missing the magneto. Was the Accurate Engineering mag the only one used on this model? How many teeth were on the mag gear. I got two gears with the engine but don't believe either one is correct. The mating gear on the engine has 48 teeth, so shouldn't the mag gear have 24 teeth? Also, the ignitor is apart in a can. Anyone have a good close up of the assemble ignitor? Thanks for the help.
Old 11-03-2008, 02:03:31 PM
Kevin Weis Kevin Weis is offline
Default Re: 1HP Mogul Magneto and Gear
Mike,
No, IHC used their own model R magneto during the later years of production of the Mogul 1 hp. This is the same mag you see on the IHC model 'M' 6 hp before they went to the Wico mag.. Hope this helps.
Kevin
The Following User Says Thank You to Kevin Weis For This Post:
Old 11-03-2008, 07:40:16 PM
Mike's Avatar
Images: 1
Looking at an old post, someone said the mag gear on the 1HP Mogul had 32 teeth. My mating gear on the crankshaft has 48 teeth. Does this sound correct?
I have a gear with the 32 teeth but the previous owner was not sure it was correct.
Old 11-03-2008, 08:14:55 PM
Mike's Avatar
Images: 1
Cancel my last question. I figured it out. The mag is a two-pole mag and every 16 teeth, it generates voltage. This times with crank fine since 3x16=48. bonk:
Gear needed for 1hp Mogul RKing Antique Gas Engine Discussion 2 09-02-2008 12:31:17 AM
1hp Mogul intermediate gear Roo Antique Gas Engine Discussion 3 04-26-2007 12:45:44 PM
Mogul S.S. Gear Removal???? Shane Ball Antique Engine Archives 0 06-29-2003 03:37:53 PM
Mogul Gear Oiling? Dan Bogart Antique Engine Archives 1 05-27-2003 09:22:35 PM
WTD MAGNETO & GEAR A.J. TELOWICZ Antique Engine Archives 0 12-22-2002 04:55:01 PM
