Maytag 72 Crankshaft
this thread has 12 replies and has been viewed 3180 times
Old 12-30-2008, 07:09:31 PM
Oilzum's Avatar
Oilzum Oilzum is offline
Default Re: Maytag 72 Crankshaft
Is it bent by the threads or the taper? The cranks on the 72 are pretty brittle, since it is not a high horsepower motor I would probably try heat with a v block and a press and just go at it real slow. Whatever you do do not strike it, even with a soft metal mallet the likelyhood of you breaking it is pretty high. Luckily, they are still pretty plentiful.
Good Luck.
The Following User Says Thank You to Oilzum For This Post:
Old 12-30-2008, 08:33:03 PM
fire96 fire96 is offline
Looks like the best bet is to locate another one!!!
Old 08-15-2018, 04:21:06 PM
Big Boose Big Boose is offline
I also have a bent model 72 crank. It locks up with new bushings..Machinist said nearly .025 at the flywheel end. He is attempting to straighten, but afraid it may break or at least crack. Anyone havea good one for sale? Thanks
Odd barn find Maytag runs again...Maytag prototype or farmer fix? Mac Leod Antique Gas Engine Discussion 16 11-19-2008 12:45:49 AM
Crankshaft Jerry B Scale Model Engineering 10 02-12-2008 01:00:45 PM
crankshaft bushings for Maytag willie G. Maytag Engine Collectibles 2 02-21-2005 08:21:06 PM
crankshaft gatweedie Antique Engine Archives 1 01-25-2004 08:57:48 PM
