Go Back   SmokStak > SmokStak® Antique Engine Community > Shows and Swap Meets > Coolspring Pennsylvania
Coolspring Pennsylvania The Coolspring Power Museum contains the largest collection of historically significant, early stationary gas engines in the country, if the not the world. Visit Coolspring, Pennsylvania for the Summer and Fall Expo and Swap Meet!
Thermoils at Coolspring
this thread has 24 replies and has been viewed 3474 times
Old 07-15-2009, 09:16:30 PM
Default Re: Thermoils at Coolspring
Originally Posted by John Cunningham View Post
I have to believe also there should be a spring but where did it go. There is no shoulder on the rod so did the spring go up against the point? Also there looks to be a sleeve for the metering rod in the body that looks frozen solid. The spring may have disintegrated from corrosion and then went down in the hole.
John,
I can't get the photos out of the camera until tomorrow.
Here are the measurements for the metering rod:
overall length - 3.717"
diameter of top segment - 0.499"
length of top segment - 1.650"
hole diameter; top - 0.312"
hole depth; top - 1.435"
diameter middle segment - 0.312
length of middle segment - 1.625"
diameter of bottom (metering) segment - 0.169
length of bottom segment - 0.442"
The bottom metering segment has a tapered flat milled onto one side which is what controls the amount of fuel. Clearance between the metering end and the seat must be at a minimum. If the rod end or seat has excessive wear (or rust damage), the fuel by-passes the end of the rod and cannot be properly metered. This tends to make the engine "hunt" severely and may run off.
The pin that operates the metering rod is 2.117" long and 0.070" in diameter in the center; it tapers slightly toward both ends.
When pushed to the bottom of the hole, the top of the metering rod is nearly flush with the top of the injector body.
You didn't say what size your engine was, but I assume it's either a six or a nine. The metering rod, I believe, is the same for both.
A word of advice from someone that's been there and back more than once...........take your time repairing the injector. I realize you're under the gun to get your engine running. Hvids are really cool and a pleasure to operate when they're right, but a less-than-perfect injector will create more headaches than you could imagine. On top of that, the smallest amount of dirt or rust in the fuel system will ruin your day.
Just a side note, the Brantford, Hoag, and Renfrew engines are the same. They were merely sold through different distributors.
Have a great time at your show!!
Kirk
The Following User Says Thank You to Kirk Taylor For This Post:
Old 07-15-2009, 09:39:31 PM
Elden DuRand's Avatar
Images: 11
John:
I agree with Kirk. He knows what's inside that fuel block and I don't. I just designed and built one from scratch so I could use my imagination.
Be very careful in fixing the metering rod. If you mess up the casting, you will be a long time finding another one.
Take care - Elden
  #23
Old 07-15-2009, 09:50:29 PM
Kyle K Kyle K is offline
Hello John. Chief Hvid Technician Taylor is a wealth of information as you have just found out. Any chance of pictures? Kyle
The Following User Says Thank You to Kyle K For This Post:
  #24
Old 07-15-2009, 10:59:47 PM
John Cunningham John Cunningham is offline
Thank you Kirk.
This information is outstanding. Thread the bore and tap hammer it back out. Here I thought it was just a sleeve and it is the actual metering rod. Why is there so much corrosion each year? I use keroscene but did not think that would cause corrosion. I will follow your advice closely. I do not recall every having this metering rod out I am glad you know what is going on there to help me.
John Cunningham with a 6 HP Hoag in Prole Iowa.
Old 11-12-2009, 11:35:27 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Here is a 1920 ad about Renfrew Coal oil engines.
Coolspring in the GEM Foos Jr Coolspring Pennsylvania 5 07-23-2008 06:51:37 PM
Coolspring J. Raney Antique Engine Archives 3 10-16-2003 08:44:50 PM
coolspring pa randall strickland Antique Engine Archives 3 10-14-2003 09:44:38 PM
Coolspring John Wall Antique Engine Archives 0 06-12-2003 05:05:41 PM
Thermoils RANDY PETERSON Antique Engine Archives 1 01-24-2002 11:55:17 PM
