Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Unidentified Engines Post your photos and questions about your unknown engine and look for answers here.
Need Help Identifying This Engine
this thread has 4 replies and has been viewed 3202 times
Old 12-11-2009, 01:25:57 PM
briggsplanet briggsplanet is offline
Default Need Help Identifying This Engine
Needing any and all information and the name of this engine. The engine is 22" high. The flywheel is 12 1/2". The bore is 3". The ignition is Atwater Kent, type CC built in Philadelphia. The carb is Marvel-Schebler VR-12, 3/4". The top of the head casting is part #1001A. On the valve cover/breather is part #1018. Please note that the valves are in the pocket on top of the headless casting. Thanks for any help you can give me, Paul
ID:	68965   Click image for larger version
ID:	68966   Click image for larger version
ID:	68967   Click image for larger version
Old 12-11-2009, 07:17:22 PM
garybtaylor garybtaylor is offline
Smile Re: Need help identifying this engine
i have a very simular engine on a holt automatic light plant made in ludington mi. around 1917 this one seems to be a little later, the valve rockers have been improved, and the ignition, there are 2 different model of this that i no of . information is rare on these. mine is 110volt dc . hope this helps:
Old 08-06-2018, 09:37:59 PM
Default Re: Need help identifying this engine
just curious do u still have his engine, it only been 10 yrs
thanks garybtaylor
Old 08-08-2018, 10:52:39 AM
Gary, I do not own the engine, never have, I was just trying to help another man. I have lost contact with him and have no idea if he owns it yet or not.
Old 08-08-2018, 02:55:34 PM
started working on the one i have and ran into a parts shortage and remembered seeing this post, thank you for your reply, i will continue looking
thank you again garybtaylor
Need help identifying engine. Dick Graybill Antique Gas Engine Discussion 9 01-29-2017 10:06:26 AM
Need Help Identifying Engine Jack Hottel Generac Generators (SEARS, etc.) 7 12-17-2010 03:22:34 AM
Need help identifying this engine Tom(ID) Small Air Cooled Gasoline Engines 17 05-15-2009 02:18:43 PM
Need help identifying this engine Lyle Kaiser Small Air Cooled Gasoline Engines 24 04-07-2008 09:36:45 PM
identifying engine Jim Scott Antique Gas Engine Discussion 2 06-15-2006 10:17:53 AM
