Go Back   SmokStak > SmokStak® Antique Engine Community > Shows and Swap Meets > Coolspring Pennsylvania
Coolspring Pennsylvania The Coolspring Power Museum contains the largest collection of historically significant, early stationary gas engines in the country, if the not the world. Visit Coolspring, Pennsylvania for the Summer and Fall Expo and Swap Meet!
COOLSPRING-35HP Bessemer twin cylinder
this thread has 24 replies and has been viewed 6813 times
Old 11-28-2010, 11:01:15 PM
Kevin Kusel Kevin Kusel is offline
Default Re: COOLSPRING-35HP Bessemer twin cylinder
The engine has been belted up to get it started. The compression is coming back. The engine ran for about 4 hours today. The plan was to get the engine running to see how far it has to be taken down for the restoration. The engine will need rings, all the bearings seam OK.
It appears they could have been running the engine off one cylinder as there was a pipe plug in the right hot tube hole and the left side has week compression. The left cylinder seams a lot more worn than the right. So it will get moved inside Justin's shop and down it will go. Hope to have some more photos of the process in a month or so.
KK
The Following 6 Users Say Thank You to Kevin Kusel For This Post:
Old 11-29-2010, 10:08:28 AM
Exclamation Re: COOLSPRING-35HP Bessemer twin cylinder
Running a twin on one cylinder may set up torsional stresses on the crank. Check all bearing surfaces and stress points. The cylinder may have been taken out of service for somthing as simple as a bad hot tube, or perhaps there is a more serious mechanical issue masked by the in-operative cylinder???. Have you tried running it on both cylinders? Good luck with your project!
Old 11-29-2010, 11:02:38 AM
Chris Austin's Avatar
Chris Austin Chris Austin is offline
Yes, they are running it on both cylinders.
The Following 2 Users Say Thank You to Chris Austin For This Post:
  #24
Old 01-08-2011, 01:26:42 AM
The engine is being torn down to have new rings put in it. The bearings look very good. Were going to keep it original and save what paint is left. Justin will complete all the bright work and the engine will be back at Coolspring Power Museum in June 2011. I will post photos as the work moves along.
KK
Old 01-08-2011, 12:28:48 PM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Here is a 1915 Bessemer adv., picture taken at the San Francisco fair. Not the best picture but the engine on the far right seems to be a twin cylinder Bessemer.
Denis Rouleau
The Following 9 Users Say Thank You to Denis Rouleau For This Post:
80 Hp type 10 Bessemer at Coolspring Power Museum Chris Austin Coolspring Pennsylvania 10 09-01-2010 05:08:27 PM
Cooper Bessemer vertical twin value W.P.Klein Oil Field Engines & Related Equipment 3 07-08-2009 02:26:27 PM
In need of a 20 hp Bessemer cylinder. DirtbikePilot Oil Field Engines & Related Equipment 38 05-04-2007 10:31:28 AM
35Hp BESSEMER Tony Page Antique Engine Archives 1 04-04-2004 03:36:35 PM
Info.&Pics of Bessemer Big Twin 165hp Tom weatherford Antique Engine Archives 0 02-17-2004 08:08:31 PM
