John Deere 1 1/2 E Governor Trouble
this thread has 7 replies and has been viewed 3362 times
Old 11-14-2011, 07:46:08 PM
Butch50 Butch50 is offline
Default John Deere 1 1/2 E Governor Trouble
What causes the trip lever to stick, holds the exhaust valve open ? What is out of location or broke ?
Harold
Old 11-14-2011, 10:31:19 PM
ksirovy ksirovy is offline
Default Re: john deere 1 1/2
Hi Harold,
The only thing I can think of is the spring on the trip is not setup right, so it stops the rod from coming back, but I'm guessing your are able to see that! Pictures help!
Old 11-15-2011, 10:37:15 PM
Mike Monnier's Avatar
Hoarder
Default Re: John Deere 1 1/2 E Governor Trouble
Make sure you have enough tension on the speed control. I've never checked it with a tachometer, but somewhere just below 300 rpm my engine will latch out and coast to a stop. Turn the speed control nut a couple turns clockwise and see if that fixes the problem.
The Following User Says Thank You to Mike Monnier For This Post:
Old 11-16-2011, 10:55:01 AM
Rich Mueller Sr's Avatar
Rich Mueller Sr Rich Mueller Sr is offline
In the John Deere manuals I have they state the gov can be set by the adjusting nut from half speed to top speed, I guess when you had a load on them they didn't want them to run slower because the gov throws the oil around and maybe it would not get enough oil at slower speeds and when oil was cold.But if you take the plate off the side there is a adjusting nut that the gov rod hits that moves the lock up latch that will take up some of the wear and slop from gov shaft bushing and gov wear,also check your STEEL cotter pins in your gov weights to see how much they are worn.Replace only with the best STEEL cotterpins you can find if there is any wear.On the adjusting nut of gov under plate, you just have to tinker to you find the sweet spot,the slowest I can get my 6hp down to is around 200,and then I also have read that running these old ones the slowest you can can break crankshafts and crack flywheels and hubs,from the shock of the fireing stroke.And running them real slow also stresses the engne more than running faster because of the slowing down and then rapid acceleration of flywheels and crank insted of a smooth run..........
United Gasoline Engine Registry www.augermo.com
Old 11-17-2011, 12:18:40 AM
I have side cover off and I think your right. Will ajust and give it a try. Thought I had a serius problem. Thanks, Harold
---------- Post added at 10:38 PM ---------- Previous post was at 10:32 PM ----------
Thanks Rich for the info, it will be very helpful. Harold
---------- Post added at 11:18 PM ---------- Previous post was at 10:38 PM ----------
what weight oil to use in this engine and how much ?
Harold
Old 11-17-2011, 06:22:55 AM
BMiller's Avatar
BMiller BMiller is offline
Thumbs up Re: John Deere 1 1/2 E Governor Trouble
I use 30 wt non-detergent, but I think it really doesn't matter a lot what you use. The manual states you should fill to the bottom of the threads, but I find that if I fill to about 1/4" below the threads, I have a lot less oil coming out. I checked that level, and it's just below the rim of the cup around the governor. There is a LOT of oil thrown around that crankcase by that governor.
Mine slows to about 150 and hits, speeding up to about 350.
Bill Miller
Old 11-17-2011, 09:18:10 AM
Bill Miller
Thanks for the info Bill.
Harold
Old 11-17-2011, 10:43:35 PM
what am I doing wrong ? In front of my name it says I moved. Don't know how that happened.
Harold
John Deere Governor Help trailrl Antique Gas Engine Discussion 12 12-11-2015 09:56:41 AM
John Deere A and John Deere R For Sale (Stuck in the snow!) Gary Biewer Antique Farm Tractors 11 01-25-2011 06:33:52 PM
Briggs governor trouble stuart olson Small Air Cooled Gasoline Engines 1 04-18-2010 06:26:18 AM
Mid 70's John Deere 110 trouble! Johnchukoloski Garden Tractors / Mowers / Scooters 7 02-07-2010 11:36:01 AM
John Deere type E fuel system trouble Tom Antique Engine Archives 6 08-02-2004 12:24:14 PM
