Band Saw
this thread has 14 replies and has been viewed 3018 times
Old 03-22-2011, 05:29:54 PM
0002tense 0002tense is offline
Default Band Saw
anyone ever convert a wood cutting band saw to handle metal? thanks all
Old 03-22-2011, 05:34:14 PM
ar2stp48 ar2stp48 is offline
Default Re: band saw
I have seen it done a few times. You have to find a way to slow the blade speed; normally an intermediate shaft is added. Have you googled the conversion?
The Following User Says Thank You to ar2stp48 For This Post:
Old 03-22-2011, 05:38:15 PM
Rod Fielder Rod Fielder is offline
All i do is change the blades on mine for wood or metal. I even freeze deer quarters and saw them up. A little messy with the meat cutting, but it all cleans up
The Following 2 Users Say Thank You to Rod Fielder For This Post:
Old 03-22-2011, 05:41:17 PM
i'm thinking a step pulley setup. it's an older cratsman with the motor down below and easy to get at. i'll take a look at google. thanks
---------- Post added at 05:41 PM ---------- Previous post was at 05:39 PM ----------
wow, isn't that a little fast for metal cutting? thanks
Old 03-22-2011, 07:39:22 PM
John Dunn John Dunn is offline
Default Re: Band Saw
Popular Machinist & Home Shop Machinist forums have many threads on the topic. Most rig up an extra pulley & jack shaft but I remember one fellow put the biggest possible pulley on the saw and the smallest possible one on the motor and claimed it worked OK.
The Following User Says Thank You to John Dunn For This Post:
Old 03-23-2011, 05:21:50 PM
J Neidig J Neidig is offline
I converted one over by using a right angle gear reducer. I don't have it anymore or I would get you some pics of it.
The Following User Says Thank You to J Neidig For This Post:
Old 03-23-2011, 09:24:46 PM
I have a 10" delta band saw that I converted using a 100 rpm, 1/4 hp gearmotor that I got at a surplus house in about 1970. On this band saw, the 1725 rpm motor that drives the saw fo woodcutting is mounted on the bottom shelf of the saw's stand and has a pulley that's about 2 or 3 inches iin diameter. To get the saw blade speed down to about 100 sfm for steel, I put a pulley of about 1 1/2" in diameter on the gearmotor's shaft. The pulley on the saw's lower drive wheel is about 6" in diameter. I mounted the gearmotor on a second shelf of the stand that I made so I could pivot it to add a belt tighteneing feature.
To cut wood, I install the nomal belt between the saw's lowe drive wheel and the 1725 rpm motor.
To cut steel, I remove that belt and replace it with a shorter belt that runs from the gearmotor to the lower dirve wheel.
The on/off switch for the saw is mounted on the top shelf, upon which the saw itself sits. I rewired the machine so the switch output wires terminate in a receptacle. Each motor has a short power cord that can plug into that switch receptacle. That way, when I switch belts to change from wood to steel and vice-versa, I also switch motor power. In this way, the same switch is always used to turn the machine motor on and off.
I have often used metal cutting blades to cut wood, but recently started buying coarse wood cutting blades and I find that it's well worth the time to change in most cases.
Obviously, I hope, one would be smart enough to NEVER use a wood cutting blade on steel.
Pete Stanaitis
The Following 2 Users Say Thank You to Pete Spaco For This Post:
Old 03-24-2011, 09:40:26 AM
John C Walker John C Walker is offline
I changed my Delta over with a DC vari drive and controller, now it can cut anything wood, plastic, steel, copper, etc. Have to keep a variety of different blades, as to be expected.
The Following User Says Thank You to John C Walker For This Post:
Old 03-25-2011, 09:22:36 PM
chrsbrbnk chrsbrbnk is offline
I used a gear reducer and a set of chain sprockets to get from 60 fpm to about 600 the pulley belt thing eats up alot of power about 50% eff. compared to chain being up wards of 90%
I sawed up a deer but the blade smelled horrible when sawing metal latter on kinda rancid smell
The Following User Says Thank You to chrsbrbnk For This Post:
Old 03-25-2011, 09:34:54 PM
hi john,
thanks, i also have a vari drive that i've tried but it seems to have a not so desirable effect on power when you slow the rpm down. maybe the drive is not right for this app. thanks again, gene
Old 03-25-2011, 09:46:20 PM
Weezer Weezer is offline
Yeah, slow the blade down to where you can count the teeth going by...$35 blade life at normal speed, about 8 seconds. So much for faster is better. Save aggravation and buy a porta-ban. Take the saw to the work. Very handy! Good luck,
Jim
The Following User Says Thank You to Weezer For This Post:
Old 03-25-2011, 10:40:45 PM
Mel Miller Mel Miller is offline
I converted an old Craftsman bandsaw to wood/metal by adding a jackshaft & pulleys to get the speed down slow enough to cut wood.
It's a lot of work, and some expense.
Some companies like Delta and Walker Turner offered an optional gearbox for metal cutting. That is really the way to go. It's easy to change from wood to metal work. You may have to look a little to find one of the wood/metal bandsaws, but will really appreciate it when you do get one.
Mel
The Following User Says Thank You to Mel Miller For This Post:
Old 03-27-2011, 07:35:35 PM
PFT's Avatar
PFT PFT is offline
I bought this saw almost 40 years ago. The owner had put the big aluminum table on it and was cutting steel. He said it worked fine, but I found that it was too fast for metal, it still had the original single reduction belt setup. I added the intermediate shaft and pulleys to reduce the blade speed, I think the speed could be reduced a little more. It has served me well for all these years so it will most likely stay the way it is.
By the way, it will still cut what it was made for, ooouch.
PT
ID:	103487   Click image for larger version
ID:	103488   Click image for larger version
ID:	103489   Click image for larger version
The Following User Says Thank You to PFT For This Post:
Old 03-28-2011, 09:04:22 AM
K D Redd K D Redd is offline
With a little shade tree engineering, one could use the shuttle pulley from a MTD built riding lawn mower to make a variable speed set-up.
Kent
The Following User Says Thank You to K D Redd For This Post:
Old 04-01-2011, 06:11:41 PM
WOW!
some great feedback here. many thanks. now all i have to do is, "geterdone"! be well
16'' doall band saw Brian.P Machine Shop and Tool Talk 4 11-17-2010 01:44:58 AM
Which way does the mag band go? Tim Claremont Hit & Miss Gas Engine Discussion 2 01-15-2009 11:10:51 PM
Gibson D brake band Dave Nesspor Garden Tractors and Mowers 3 12-20-2008 07:56:47 PM
Name band for sumter mag Dustin D Ehli Magnetos, Ignition Coils and Spark Plugs 0 01-09-2008 02:49:15 PM
IHC Mag, brass band??? Kevin Woodruff Magnetos, Ignition Coils and Spark Plugs 3 05-11-2006 04:37:53 AM
