IHC LA or LB Gas Tank Rust Problems
this thread has 9 replies and has been viewed 2062 times
Old 11-30-2010, 12:07:58 AM
wielenberg123 wielenberg123 is offline
Default IHC LA or LB Gas Tank Rust Problems
I have a couple of gas tanks that are rusty on the inside. They are not rusted though just surface rust. I am looking for ideas on how to shine the inside of the gas tank up. Once thats done I plan on putting a sealer in them. On one of my F-20 gas tanks i dumped a couple cups of crushed rocks in their, put in some gas. Then I rolled it around and shook it. It turned out very nice inside when I was done. I am not sure if thats the best way to do these smaller, not so heavily built tanks. Any help would be appreciated. Thanks
Mike
Old 11-30-2010, 06:14:25 AM
Francis Francis is offline
Default Re: IHC LA or LB Gas Tank Rust Problems
In case of a leak after you have cleaned your fuel tank internally, here is an interesting article on how to repair a leaking LA/LB fuel tank - http://www.gswagner.com/lalbtank/lalbtank.html
The Following 2 Users Say Thank You to Francis For This Post:
Old 11-30-2010, 10:46:40 AM
Thanks for sharing that website!!!!
Old 11-30-2010, 11:23:09 AM
mnido mnido is offline
I took a die grinder to my LA tank and cut the bottom off. Then sandblasted the inside off the tank. Then sat it over a piece of sheet metal, scribed it, cut a new bottom, then stitch welded around the entire tank. Then I used a tank sealer. Lot of work but turned out nice, and also looks original.
Old 11-30-2010, 11:45:17 AM
Zira Zira is offline
I did mine similar to what you did for you F-20 tanks, except I used acetone instead of gasolene as I had some varnish as well that needed cleaning out. It worked fine but it was very difficult to get all teh gravel out because of the baffels inside the tank.
Old 11-30-2010, 02:41:33 PM
Meco3hp's Avatar
Meco3hp Meco3hp is offline
Hello,
I did like Mnido did with his. I cut the bottom out, plasma cut another bottom at work. Bead blaster everything, and welded it back up. Then I sealed everything! Oh I also added a drain in the bottom so I can drain the tank without removing it from the engine. I don't know why IHC never put a drain in these tanks! Oh, I made the bottom out of 10 ga. sheet. The rest of the tank will rust away before that bottom ever does!
Thanks!
Richard
Old 12-01-2010, 07:49:13 PM
Thanks For all the ideas guys!!! I will probally try the shingle nails and some gas. I dont have a plasma or wire feed welder easily accesible!
Old 12-01-2010, 08:29:49 PM
midpw midpw is offline
I like the response from the one fellow awhile ago. He removed the tank from wherever it was, dumped in a couple handfuls of 1/4-20 nuts that he had, closed it up and then tied the whole thing to the rear tire of a tractor. Jacked up that same side and then ran the darned thing in gear for a while until he couldn't stand the noise any longer. Clean as a whistle...
Bruce
Old 12-01-2010, 11:30:53 PM
MarkBillesbach's Avatar
MarkBillesbach MarkBillesbach is offline
Mike,your tank bottom looks like the bottom on my M tank. On mine I got the inside clean by electrolosis,then I put aluminum tape over the outside (bottom).Then I used POR gas tank sealer on the inside. After the sealer cured I removed the aluminum tape and it looks like new and dosn't leak a bit.
The Following User Says Thank You to MarkBillesbach For This Post:
Old 12-02-2010, 02:24:28 PM
Reed S. Benton Reed S. Benton is offline
You will cringe, but I had success cleaning the tank on my 1.5HP McCormick; put muriatic acid in for a few minutes, thoroughly flushed and neutralized and then "slushed" it
Evapo-Rust rust removal process. NAMPeters Hit & Miss Gas Engine Discussion 15 12-07-2009 03:40:10 PM
Problems brazing a small fuel tank John A Welding Shop 7 04-24-2009 11:33:09 AM
Tank sealer in a installed tank Gilbert_Bates Hit & Miss Gas Engine Discussion 10 07-21-2008 08:40:02 PM
rust in fuel tank Tim0477 Generators & Electric Motors General Discussion 3 11-01-2005 10:06:43 PM
Tank problems (Fuel) Ryan Price Antique Engine Archives 3 05-29-2003 05:31:12 PM
