Jacobson Machine Mfg. Co., Warren, Pennsylvania
this thread has 394 replies and has been viewed 74627 times
Old 03-13-2014, 08:35:28 PM
Don Worley Don Worley is offline
Default Re: Jacobson Machine Mfg. Co., Warren Pa.
Sherwood Mfg
Old 03-15-2014, 06:26:24 AM
Last entry for the automatic engine. This one is set up for gasoline. Apparently they were in a hurry to get a picture. You can see the maroon pain with drippings of the red lead primer from the intake, which appears to have been added later, over the maroon paint. Jeff is correct that the pictures were turned into illustrations. You can see that the base from the previous picture has been removed. They didn't have to worry about how the paint job looked. The illustrator would remove the defects for the final version used in the advertising bulletins. You can also see the adjustable head on the ignition trip rod which was used on the larger engines.
Old 03-16-2014, 06:45:15 AM
Rendering of the Warren tandem engine.
The Following 8 Users Say Thank You to Don Worley For This Post:
  #324
Old 03-17-2014, 10:48:01 PM
This may be the oldest 4 HP. It has the "patent applied for" on the base. No serial number or evidence of a name tag were found.
ID:	190907   Click image for larger version
The Following 13 Users Say Thank You to Don Worley For This Post:
  #325
Old 03-18-2014, 10:48:33 AM
Doug Sather Doug Sather is offline
Don: what kind of ignitor set up is that?
The Following User Says Thank You to Doug Sather For This Post:
  #326
Old 03-18-2014, 07:20:15 PM
Home made. It is being changed to the correct one.
The Following User Says Thank You to Don Worley For This Post:
  #327
Old 03-21-2014, 05:33:16 PM
From one of the Warren papers. As a note the first 5 years of my life I lived at 18 Crescent St.
The Following 4 Users Say Thank You to Don Worley For This Post:
  #328
Old 03-22-2014, 05:41:00 PM
Daniel Dorece Daniel Dorece is offline
This appears to be a Sturdy Jack made into an air compressor.
The head is made like a compressor not like an engine, it extends down into the cylinder about an inch to raise the compression. The clutch came with the engine. It had been in a fire before I got it and although I can see were a tag was it was melted into a couple of little blobs. This certainly looks like a factory built compressor and I wonder if Jacobson built it or sold the parts to someone else. The area where the cam and valve train go is not all machined. This is mounted on a truck with my Pierce inverted "V" twin to provide a load for it since the Pierce runs absolutely awful without a load.
IRON WOLF
P. S. See next for a couple of more pix.
ID:	191216   Click image for larger version
ID:	191217   Click image for larger version
The Following 4 Users Say Thank You to Daniel Dorece For This Post:
  #329
Old 03-22-2014, 05:45:22 PM
Here is the clutch and the compressor on the truck with the Pierce.
ID:	191219   Click image for larger version
The Following 5 Users Say Thank You to Daniel Dorece For This Post:
  #330
Old 03-23-2014, 05:31:58 PM
This definitely a Jacobson compressor. Look on the flywheel hub face of the cam side flywheel for a possible serial number.
Machine shop in western Pennsylvania? J. Sutter Antique Gas Engine Discussion 3 09-25-2014 09:33:33 PM
THe Little Elgin-RA warren Tom Hartfield Small Air Cooled Gasoline Engines 1 03-05-2012 05:31:18 PM
Jacobson Machine Mfg. Co. Warren, Pennsylvania (PICTURES) Denis Rouleau Antique Gas Engine Discussion 10 06-18-2011 11:15:59 PM
WD-40 IH at J.B. Warren Sale Eric Best Antique Farm Tractors 0 09-23-2005 09:35:45 PM
