Steam Engines
Pickering Mechanical Lubricator question
this thread has 4 replies and has been viewed 1654 times
Old 06-30-2009, 02:48:36 PM
Zachary Rukstela's Avatar
Zachary Rukstela Zachary Rukstela is offline
Photo Pickering Mechanical Lubricator question
Hey gang,
We just received this donation of a mechanical lubricator (see attached photos). The Cover says:
PICKERING
PORTLAND
CONN. U.S.A.
PAT NO 849530
PAT NO 857221
-The mounting holes on the back side of the unit are threaded.
Anyone have thoughts on what this unit would have been used for? I’m familiar with Pickering governors, but have never seen a lubricator.
Thanks,
Zachary
Name:	Pickering Lubricator 002.jpg
ID:	57676   Click image for larger version
Name:	Pickering Lubricator 003.jpg
The Following User Says Thank You to Zachary Rukstela For This Post:
Old 06-30-2009, 03:02:22 PM
David's Avatar
David David is offline
Default Re: Pickering Mechanical Lubricator question
"Anyone have thoughts on what this unit would have been used for?"
It would be interchangeable with any application that would use a Manzel, Practical, Madison-Kipp, or McCord lubricator.
David
Old 06-30-2009, 03:14:44 PM
Thanks David. I agree with what you're saying but it’s built much more beefy then anything I’ve seen on a traction engine so I though maybe it would have been in an industrial application? Power Plant perhaps?
Old 06-30-2009, 03:25:38 PM
David's Avatar
The early mechanical lubricators were made out of cast iron. Both Madison-Kipp and Manzel made a much heavier cast iron lubricator before going to the formed steel ones that are more common today. A lot of the earlier Frick engines came out with a cast iron mechanical lubricator.
In the old days, when it doubt, make it heavier. A rule of thumb that some engine manufacturers followed.
I expect the lubricator competition was too stiff for Pickering, and they dropped the lubricator line and focused on the governor business.
David
The Following User Says Thank You to David For This Post:
Old 06-30-2009, 05:01:55 PM
Eric M.'s Avatar
Eric M. Eric M. is offline
The 1902 Advance at Vista has an early Madison-Kipp on it that has many similar features to this Pickering. They both have an external ratcheting mechanism, they both are all cast-iron construction, neither has a sight-feed, and both have all their information cast into the cover in raised letters. Several details are different though, so I doubt both were made by the same company.
Hey, if you got it, use it!
The Following User Says Thank You to Eric M. For This Post:
Detroit Lubricator Question? Nicholas Carrier Hit & Miss Gas Engine Discussion 1 07-10-2008 11:25:46 AM
Powell Lubricator Question Tom Martin Steam Stationary Engines, Traction Engines 11 09-16-2007 10:36:02 AM
Mechanical oiler question John W Oil Field Engines & Related Equipment 1 12-18-2006 04:51:41 PM
dETROIT Mechanical Lubricator. Joel Mosley Hit & Miss Gas Engine Discussion 10 10-06-2005 09:27:30 AM
Mechanical Repairs Bill Calvert Antique Engine Archives 3 09-30-2002 10:33:11 PM
