Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Wood Shop and Projects
Wood Shop and Projects Engine Skids & Carts, Pattern Making, General wood shop projects and tools.
Identify Type of Auger Tool / Handle Assembly?
this thread has 6 replies and has been viewed 553 times
Old 05-15-2019, 07:23:33 PM
tabbyapple tabbyapple is offline
Default Identify Type of Auger Tool / Handle Assembly?
A wood handle has been added to the upper horizontal bar of this T-shaped tool for added torque. The upper bar inside the wood is 7" long and the tool is 6 3/4" tall. The lower threaded area is 3/4" wide and tapers down 9/16" on the bottom.
If this some type of a tappered boring auger or simply a attachment for bits?
Old 05-15-2019, 07:29:15 PM
Heins Heins is offline
Default Re: Identify Type of Auger Tool / Handle Assembly?
I would say it is to cut threads into wood holes.
Old 05-15-2019, 07:34:05 PM
Thanks! My brain drew a blank for some reason. Thats makes sense - first drill a 9/16" diameter hole and then drill this tool into the hole to create internal threads which have a maximum width of 3/4".
Old 05-15-2019, 10:45:58 PM
ulgydog56's Avatar
its fluted, got to be some type of tap, for maple trees? lol....
Old 05-20-2019, 07:08:45 PM
Yes, definitely a tap for threading holes into wood.
Usually pretty expensive, too.
Pete Stanaitis
Old 05-21-2019, 09:46:39 PM
Acme thread tap for wood, such as threading for a broom handle?
Bill
Help identify heart shape handle water pump? Firewoodguy Farm Antiques and Collectibles 4 05-07-2019 09:01:02 AM
Please identify this engine-pump assembly David Mi Vintage Toy Steam Engines and Motors 1 04-26-2012 06:48:31 PM
Can you identify this crank handle ? Andrew Walker Hit & Miss Gas Engine Discussion 4 07-04-2011 12:05:43 AM
Unknown Crank Handle, Please help me Identify!! Jeff Holbrook Hit & Miss Gas Engine Discussion 1 05-15-2011 11:36:58 PM
Old wood type auger drill bit Barnbikes Farm Antiques and Collectibles 7 10-20-2006 04:24:42 AM
