Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Blacksmithing and Metallurgy
Blacksmithing and Metallurgy Hand-wrought manufacture of metal objects, extracting metals from their ores, or purifying metals and casting useful items from the metals.
New to Blacksmithing
this thread has 16 replies and has been viewed 2628 times
Old 02-12-2017, 10:12:14 PM
Dustin D Ehli Dustin D Ehli is offline
Default New to Blacksmithing
Been pondering this for a while but finally started tooling up to start ornamental blacksmithing this spring,
Keeping my workstation mobile at the moment so built stands that have wheels on one end for wheelbarrow effect.
Just have a small old solid fuel forge at the moment but want to get a gas one soon as well.
Don't really know what I'm doing but trying.
As you can see my leafs are improving from the two pics, tried a mouse but screwed up the ears so it looks stupid but learned a few things.
ID:	274804   Click image for larger version
ID:	274805   Click image for larger version
Having a blast preserving the past.
My Youtube Channel
The Following 7 Users Say Thank You to Dustin D Ehli For This Post:
Old 02-12-2017, 10:16:36 PM
Default Re: New to blacksmithing
Here is the forge I currently use, and my main and auxiliary stands for working on.
Like I said they are set up to move like a wheelbarrow, works pretty good.
I'm always looking for more reasonable priced anvils and equipment if anyone has any
ID:	274807   Click image for larger version
ID:	274808   Click image for larger version
My Youtube Channel
The Following 3 Users Say Thank You to Dustin D Ehli For This Post:
Old 02-12-2017, 11:02:35 PM
s100 s100 is offline
Default Re: New to Blacksmithing
"Don't really know what I'm doing but trying."
Judging by your pictures, you are off to a very good start indeed. I really like the portable workstation idea too.
Old 02-12-2017, 11:13:58 PM
Leafs came from 1/2 hot rolled square.
Mouse attempt was 3/4 square hot rolled
My Youtube Channel
Old 02-13-2017, 07:42:23 AM
Since I use the small rail pieces for finishing and small work it is plenty strong in my opinion, trust me.
We have had some fantastic weather this weekend and looks very nice through the coming weekend too so might do some more.
As crazy as it sounds me and a co worker might try to make our own hammers this spring, we are currently talking to a friend in the steel business to source us some heavy steel plates ( thinking 3 inch thick) to make striking anvils out of for heavy duty sledge work
My Youtube Channel
Old 02-13-2017, 07:53:45 AM
MotorMike MotorMike is offline
Looks great Dustin, I too am going to try out blacksmithing soon, our club just yesterday approved the construction of a blacksmith shop, and we have a seasoned veteran blacksmith to learn from.
The Following User Says Thank You to MotorMike For This Post:
Old 02-13-2017, 06:48:14 PM
These are the tongs I have to work with at moment, bottom one is a brand new 1/2 v bit. Of course I occasionally use a non blacksmithing approved tool like a needle nose pliers but oh well.
If I can convince my wife to film a couple times iight start uploading videos to my YouTube, of course they will suck but someone might get enjoyment out of them
My Youtube Channel
Old 02-14-2017, 11:32:41 AM
I have seen more than one guy using visegrips for tongs.
Many years ago we saw a group of Hmong blacksmiths who didn't use tongs at all. They simply had a bucket of water and a bunch of rags. They'd dip a rag in the water and use the rag in one hand to hold the work.
Your stands look quite similar to Farriers benches that I have seen. I have worked on those benches often over the years and they are quite acceptable.
By the way, the Farrier's benches have flat wooden or steel work surfaces, making it easy to hold tools and stock close to the anvil, etc.. Even a coffee cup.
Pete Stanaitis
---------- Post added at 09:32:41 AM ---------- Previous post was at 09:22:00 AM ----------
Whoops! Sorry! I looked at your pictures again and I see that your stands have storage surfaces, too.
I meant to mention that a great source for hammer head stock is Caterpillar track pins. They come in many different sizes, as you might expect. The SOLID ones.
They are 1055 steel, which is just right for hammers. Every time a track wears out, you get a whole bunch of them. I guess the "modern" ones are hollow and may be clad in some abrasive-resistant material, so I wouldn't use them.
But, if you start asking around, sooner or later you will find them. Many "local" Cat dealers used to repair tracks but I don't think that's so common any more. I think they send them away to some place that specializes in that work.
But you never can tell what an old Cat dealer might have in a barrel out back. Or what you might find at a blacksmith event where tailgating is common.
Pete Stanaitis
The Following User Says Thank You to Pete Spaco For This Post:
Old 02-14-2017, 05:25:21 PM
i was thinking the same thing, i could use a few more pairs that have bigger openings in them.
they dont look too complicated. and the good thing is they dont have to be pretty to be useful
My Youtube Channel
Old 02-19-2017, 05:42:01 PM
Have made my first set of tongs, I wanted some that had a larger opening when the handles were closed, for holding thicker stuff.
I think they turned out OK, I cheated and used a bolt for the pivot.
Made a few more leafs as well
My Youtube Channel
The Following User Says Thank You to Dustin D Ehli For This Post:
Old 03-07-2017, 06:59:25 PM
Working slowly on tools to make hammer some day.
This is my completed hammer eye punch.
Made from a sway bar.
My Youtube Channel
Old 03-07-2017, 07:21:16 PM
Gasenginegangster Gasenginegangster is offline
Thumbs up Re: New to Blacksmithing
The work so far on the leaves and mouse look good. Keep at it!
Old 03-11-2017, 02:31:23 PM
Striking anvil done, gonna use for heavy duty work
My Youtube Channel
Old 03-11-2017, 04:05:02 PM
Filled with dry sand, didn't want the oozing oil mess if the welds were not perfect.
Hint, if you place an ergo mat under the feet you can use a sledgehammer and it doesn't even wiggle.
Looking forward to abusing the hell out of it.
Gonna work on a big hammer eye drift tomorrow from a car axle
My Youtube Channel
Old 03-12-2017, 06:29:56 PM
Calla lilies
What do you all think.
My Youtube Channel
Old 03-07-2018, 05:35:32 PM
DBH DBH is offline
I would recommend "The Backyard Blacksmith" By Lorelei Sims as a great book to get. Order it from her at blacksmithchic.com
It has great color pictures & good instructions on how to do the projects in the book. A great resource!
Dave Huffman
Old 03-24-2018, 01:15:42 PM
DBH DBH is offline
Lightbulb Re: New to Blacksmithing
Nice work on the tongs! You might forge a V in the bits AKA ends of your tongs. Just use a piece of square stock on edge to form the V. Does not have to be to big of a V but you will get a much better grip on your stock. Hope this helps.
Dave Huffman
---------- Post added at 12:15:42 PM ---------- Previous post was at 12:10:15 PM ----------
Mass is your friend for anvil stands. Been there, done that & got the T-shirt
Blacksmithing Andrew Albrecht Blacksmithing and Metallurgy 17 12-19-2012 11:00:15 AM
Celtic Blacksmithing DaveMisch Blacksmithing and Metallurgy 5 07-23-2012 06:22:04 AM
Blacksmithing instruction PDF downloads PTSideshow Blacksmithing and Metallurgy 0 01-08-2010 11:39:26 AM
Books on Blacksmithing Chris J Blacksmithing and Metallurgy 16 04-25-2009 08:35:03 AM
