Onan Older 2 Cylinder Needs Help!
this thread has 15 replies and has been viewed 3081 times
Old 04-11-2012, 08:41:23 AM
rebecn rebecn is offline
Default Onan Older 2 Cylinder Needs Help!
I have an older Onan engine (welder/generator, I believe 1954 era) that I trying to restore (M# CK-S/259K, S# 124B511486, 10.1 HP @ 3000RPM). I am looking for specifications, service manual, parts supply and any help/advice. Yes I have only one "C" in my model #, just about all of my research has shown two "C", what do I actually have?
NOR, Thank you
Old 04-11-2012, 09:43:34 AM
Billy J Shafer's Avatar
Default Re: Onan older 2 cylinder needs help!
You have the CK. Which became the CCK. Your engine was built in December 1954.
Old 04-11-2012, 11:09:57 AM
Bob Whitney Bob Whitney is offline
rebecn
I have had, fairly good luck with finding, operators and parts manuals on line for my equipment? Free down load, is good.
Google your welder and look for free manuals, ect? There are also, you bye manuals. You might get lucky and find what you need?
Bob
The Following User Says Thank You to Bob Whitney For This Post:
Old 04-12-2012, 05:15:24 AM
Thank you for the info, I will do more searching on the web for a CK manual. I thought it was strange that when I went to our local Onan dealer they never heard of a CK and their listing had only CCK.
Old 04-12-2012, 08:29:23 AM
I have parts manual 910-92 for the CK. Send me a pm with your e-mail address and it's yours.
The Following User Says Thank You to Ed Sparks For This Post:
Old 04-14-2012, 11:40:33 PM
norebecchi@sbcglobal.net, and else do you need?
Old 04-15-2012, 12:21:41 AM
Check your e-mail for 910-92
---------- Post added at 12:21 AM ---------- Previous post was at 12:16 AM ----------
Old 07-05-2012, 06:36:48 AM
snakeknuckles snakeknuckles is offline
I've been excersizing my ck-s/259k as a generator in our last power outage. It has developed an intermittent knocking sound that seems to be coming from the camshaft area...maybe timing chain? Anyway could you email a copy of that manual? - bobby@fspeoples.com
Thx
Old 07-06-2012, 12:13:48 AM
moteurdelco moteurdelco is offline
no chains ,only gears.lifetime garantie.
Old 09-24-2018, 12:56:37 PM
JLiebermann's Avatar
JLiebermann JLiebermann is offline
Default Onan CCK S797F
Engine has ignition prob. Ordered ignition condenser, Coil, and points. When I opened breakler box I found another condenser inside.
Does this engine have two condensers or was there an engineering change and someone forgot to remove the old condenser?
Thanks in advance for any help!!
John Liebermann
D69U, D69U, IHC544, Ford860, D25J, Hardie Spray Rig, 67Chev C10 Short Narrow Box, Dodge Cummins 1990 W250
Old 09-25-2018, 02:00:49 AM
cobbadog cobbadog is offline
Can't see any reason for 2 condensors in the one system. Maybe one failed and a replacement fitted elsewhere and wired in place there. I have been using film capacitors instead of condensors over the last couple of years. These are more reliable and can be very small in size but big in capacity so they can be fited almost anywhere. I prefer the ceramic ones over the plastic ones just as a heat shield issue. Try using one with values of 600V and 0.22Mf. No positive or negative sides just insulate one side going to your points with plastic or shrink wrap.
Old 09-25-2018, 09:38:32 AM
Thank you cobbadog for you help. The second condenser was attached outside the breaker box. I dont remember who/when I had work done on this engine last. It has not been in use for the past 8 yrs or so but did not run correctly when I tried to start it.
Anyway I ordered new points, condenser, and coil and they sent a condenser that matched the one that was attached to the outside of the breaker box.
The engine does not run with the inside condenser removed from the circuit so I am going to replace the coil now and take the cost hit.
Hopefully the pic got attached.
John Liebermann
Old 09-26-2018, 02:17:20 AM
Default Re: Onan Older 2 Cylinder Needs Help!
Good news that you have resolved the mystery about the extra condensor. Interesting in your picture that both the points and condensor look very similar to those used on our very early Victa 18 lawn mowers. Those ignition parts were made by Wico out here.
Old 07-19-2019, 02:22:07 PM
I received new points, condenser, and coil. The setup is quite different so had to have the beaker box machined and the coil will be mounted outside and run from 12V battery. The pushrod that opens the points will need re fabrication.
I am not enxt to the engine until later this month and will hopefully get back on this project.
John Liebermann
Old 07-20-2019, 02:51:29 AM
Look forward to your ongoing success.
Old 07-20-2019, 09:26:58 AM
Is your engine on a welder, generator, or the stand-alone industrial engine? Do you have the manuals for the CK Industrial Engine? Only one condenser needed, and the outside is just an alternate mounting method for a more common style condenser. These are a little different than the generator CK I'm used to.. The older version had battery ignition, maybe model your circuit on that I'll be interesting to see what you come up with
Maybe start a new thread for your model..
Instruction
http://www.skilledcrafting.com/onanf...20(5-1964).pdf
Parts
http://www.skilledcrafting.com/onanf...s%20manual.pdf
ONAN Trying to identify an older single cylinder Onan joeaksa Onan Generators 12 08-15-2015 11:10:51 AM
Should I buy this 15 kw Older Onan genset? ocman Onan Generators 5 09-10-2010 11:17:41 AM
Older ONAN 5ACK thefonz6752 Onan Generators 4 02-28-2009 07:07:18 PM
Indentifying older ONAN signgroup Onan Generators 8 01-29-2006 11:18:32 AM
Older Onan Followed Me Home........ midpw Onan Generators 4 05-24-2005 01:44:17 PM
