Sandwich engine magneto lever
this thread has 11 replies and has been viewed 1311 times
Old 02-07-2016, 10:19:28 PM
wan56 wan56 is offline
Default Sandwich engine magneto lever
I just bought a Sandwich 2hp engine. I has a cast iron lever next to the mag and I have never seen one of these. It trips the mag and retracts. I am wondering what it's for? I have not started this engine yet, it needs a little work but will be trying soon.
Old 02-07-2016, 10:22:56 PM
Matt Weismiller Matt Weismiller is offline
Default Re: Sandwich engine magneto lever
Its used for starting the engine or you can shut the engine off with this lever.
The Following User Says Thank You to Matt Weismiller For This Post:
Old 02-07-2016, 11:16:47 PM
Thanks, I suppose you can prime the cylinder and pop the mag for the start or hold the mag down for the stop.
Old 02-08-2016, 12:50:36 AM
Yes it will also work for bump starting the engine
Old 02-08-2016, 07:35:04 PM
Thanks much.
Old 04-17-2016, 04:20:45 PM
Target Driller Target Driller is online now
Dug my 1-1/2 hp Sandwich out from the mothballs today and cranked it up for the 1st time in many years. Figured the gas was varnished, but viola it perked right up. ... I have that same lever device on the mag and never knew it could be used as a bump start device. Will have to give it a try.
uploading pictures
Old 04-17-2016, 04:53:56 PM
newway1978 newway1978 is offline
gould shaply and muir brantford cub has the same idea on thier copy of this engine
Old 04-17-2016, 09:37:41 PM
Rick I Rick I is offline
Target Driller, what does it say on the side of the lever? In the photo there looks like something there. Neither the Wico EK instruction/parts manual or service manual show any drive type with a lever like this and I'm wondering if it was a Sandwich company special part.
Thanks,
Rick I.
Old 04-18-2016, 04:52:29 PM
Hi Rick,
hey thanks for noticing that ... good eyes! ... The embossed letters read
"Pat 6-23-1925"
free photo upload
Old 09-19-2017, 06:57:40 AM
See photo in Post #5; at the left side of the magneto lever there is a vertical stack of washers/spacers with a open hole; Is there suppose to be a retaining "pin" of some type poking through the spacers?
If so, does anyone have a better view or even better dimensions of the pin so I can reproduce one?
Thanks!
Old 09-19-2017, 07:30:10 AM
SparkyMil SparkyMil is offline
I think that is the spring you are referring to as a stack of washers.
Old 09-19-2017, 07:45:25 AM
Thanks Sparky; "Yes" that would make sense. I appreciate that clarification.
Webster tri-polar magneto trip lever Dick Briggs Magnetos, Ignition Coils and Spark Plugs 2 11-04-2015 06:33:53 PM
Sandwich Engine Trip lever springs needed. ShaneZahn Hit & Miss Gas Engine Discussion 0 08-30-2015 08:34:56 AM
Hercules Webster magneto trip lever Lanzb Smokstak Down Under 3 12-28-2012 05:57:22 PM
M 1 1/2 Magneto Trip lever onstottc Hit & Miss Gas Engine Discussion 3 12-17-2011 10:36:04 AM
Webster Magneto Starting Lever portlandron Magnetos, Ignition Coils and Spark Plugs 2 12-05-2011 01:55:26 PM
