Magneto Application IDs
this thread has 9 replies and has been viewed 536 times
Old 05-20-2019, 06:50:57 PM
Sad Iron's Avatar
Sad Iron Sad Iron is offline
Default Magneto Application IDs
Found several 2 and 4 cylinder magnetos tonight in the shop but we don’t have much experience with them. Wondering if anyone can help us figure out what they all fit:
Simms Type 04
Eiseman 2 cylinder model GL-2H
KW model T 1 cylinder & international 4 cylinder (cant find model)
Another IHC without cap (has F4-321287 in serial no. Block)
Jonathan
ID:	335240   Click image for larger version
ID:	335241   Click image for larger version
ID:	335242   Click image for larger version
Old 05-20-2019, 08:23:02 PM
Sad Iron's Avatar
Default Re: Magneto Application IDs
The only info on the 2nd mag in the 3rd pic is a 20 stamped in the casting and “patents pending” on a brass tag on one side.
Old 05-20-2019, 09:13:07 PM
Gene Williams Gene Williams is offline
The Eisemann is for a Caterpillar pony motor, the KW is for a one cylinder Mogul, the IHC is an E4A for a Farmall regular, 10-20 15-30 or 22-36 McD
The last one without the cover is an IHC F4 for F-12 F-14 or F-20
The Following 2 Users Say Thank You to Gene Williams For This Post:
Old 05-20-2019, 09:26:36 PM
Sad Iron's Avatar
Fantastic, thanks Gene!!
Old 05-21-2019, 02:22:17 AM
cobbadog cobbadog is offline
It appears to have another number above the hole in your post #2. It is on a raised section of alloy.
Good they have been identified for you too.
Old 05-21-2019, 07:32:49 AM
Craig Gillingham Craig Gillingham is offline
The Simms C4 were used on a few engines, depending on the rotation, the 20's Henderson and Ace motorcycles used them.
The Following User Says Thank You to Craig Gillingham For This Post:
Old 05-21-2019, 08:47:53 AM
Sad Iron's Avatar
Hi Cobbadog.
Correct, its "20"
J
The Following User Says Thank You to Sad Iron For This Post:
Old 05-21-2019, 09:13:29 AM
naylorbros naylorbros is offline
The model of magneto for the Caterpillar pony motors is a Eisemann GV2Q. The GV2Q was replaced by the RC2Q or RT2Q. A RT2H or RC2H with a horizontal flange mount was used on the D2, D4 and D6 starting engines. An Eisemann GL2 was used on the earliest starting engines.
Ken
The Following User Says Thank You to naylorbros For This Post:
Old 05-21-2019, 07:33:00 PM
Sad Iron's Avatar
Hi Ken
When you say earliest starting engines you mean pre-caterpillar?
Thanks for the info.
Jonathan.
Old 05-22-2019, 09:24:42 AM
No. When I say early earliest starting engines for Caterpillar I am talking the D9900, early D11000, D7700 etc engines. I do not have my parts books here so my serial # breaks may be wrong, for example the Diesel Seventy-Five tractors 2E1 to 2E213 would have used the GL2 magneto. Diesel Seventy-Five tractors after 2E214 would have used the GV2Q magneto
Magneto application Lonnie Grissom Magnetos, Ignition Coils and Spark Plugs 4 04-01-2019 06:25:39 PM
Bosch FB-1 Magneto Application Jason Dahm Hit & Miss Gas Engine Discussion 0 04-01-2014 10:52:47 AM
what is the application of this magneto? Charlie Mc Magnetos, Ignition Coils and Spark Plugs 1 11-08-2012 07:32:22 PM
Magneto Application Question J Kocak Magnetos, Ignition Coils and Spark Plugs 1 01-14-2009 08:42:31 PM
Magneto Application jerry larner Antique Engine Archives 0 11-12-2003 09:16:10 AM
