Bosch DU4/2
this thread has 6 replies and has been viewed 499 times
Old 05-30-2019, 07:41:44 AM
Jack Innes's Avatar
Jack Innes Jack Innes is offline
Default Bosch DU4/2
Hello, I have a new to me Rumely X25-40 with a Bosch DU4/2 magneto that has a deteriorating bearing or bearings. This likely is due to the mag being under a bolted on cover & does not get oiled very often.
My question is, if the armature is damaged will an armature from a DU4 fit & work? I have several DU4 mags. Or can a DU4 be converted to a DU4/2?
Thank you,
Jack
Old 06-01-2019, 12:02:21 PM
Eric B. Eric B. is offline
Default Re: Bosch DU4/2
I believe they are armatures are interchangeable.
The Following User Says Thank You to Eric B. For This Post:
Old 06-02-2019, 10:47:46 AM
Jack Innes's Avatar
Thank you Eric, so if I change the cap assembly & interrupter housing I can make my rebuilt DU4 work as a DU4/2 ??
Jack
Old 06-02-2019, 12:30:34 PM
stufforbud stufforbud is offline
You only have to change the cap and make sure the unused terminals are grounded.
The Following User Says Thank You to stufforbud For This Post:
Old 06-02-2019, 07:00:36 PM
Jack Innes's Avatar
Thank you for the information. I have made a bit of a commitment to repair the DU 4/2, the new bearings arrive tomorrow. If it does not work well I will convert the known DU4 that I have. I also made some tools to do the job. (not the mag wrench)
ID:	336171   Click image for larger version
The Following User Says Thank You to Jack Innes For This Post:
Old 06-03-2019, 11:11:48 AM
Reeves13hp's Avatar
Reeves13hp Reeves13hp is offline
Card Sponsor
Like posted above armature should be the same. The only difference iv ran into is with the front pickup being different but I think that is mostly on older du4's.
I recently installed some new bearings and I was always told to use phone book cover paper as the insulator shims. On this particular mag I ended up having to take a race back out to install a different piece of paper for the face paper because the bearings were too tight when I installed the rear cover.
Chris
8-1/2x10 Frick
13hp Reeves
50hp Case
22hp Wood Brothers
18hp Advance
20-75 Nichols & Shepard
20hp Corner Bracket Advance
16hp Minneapolis
The Following User Says Thank You to Reeves13hp For This Post:
Old 06-03-2019, 06:52:54 PM
Jack Innes's Avatar
Thank you Chris. I installed the new bearings today & assembled the magneto. It seems someone in the past did not understand the concept of the shims & shimmed the drive end race with brass. That was the bearing that was worn considerably. I found that file folder paper is .010" thick & of good quality. It worked well & the bearings are now isolated electrically. Perhaps I will try it on the Rumely tomorrow.
Jack
Bosch Du4 and AT4? BobM Magnetos, Ignition Coils and Spark Plugs 3 03-25-2017 06:50:06 PM
Bosch May Steve Kreiner Hit & Miss Gas Engine Discussion 4 11-11-2014 06:50:11 PM
Bosch Fx1 Ray Cardoza Magnetos, Ignition Coils and Spark Plugs 3 11-01-2014 01:50:26 PM
American Bosch, Bosch magneto ZR4 vs DU4 Interchangable? glenshep Magnetos, Ignition Coils and Spark Plugs 4 03-25-2014 02:19:07 AM
Bosch DU1? ssimntih Magnetos, Ignition Coils and Spark Plugs 1 10-19-2009 03:42:16 PM
