briggs ZZ plug wire insulation
this thread has 7 replies and has been viewed 340 times
Old 07-16-2019, 12:36:28 AM
pigpen60 pigpen60 is offline
Default briggs ZZ plug wire insulation
Where the plug wire solders to the armature on a briggs ZZ, what do you use to insulate this? I read the manual and it says to save the putty or ? to reuse but mine is dry and brittle.
Old 07-16-2019, 07:25:08 AM
Mike in NC's Avatar
Default Re: briggs ZZ plug wire insulation
Do not solder the plug wire to the coil lead out tower. Tin the end of the wire, thread it thru the lead out tower and bend the end of the wire over. Soldering the tower can damage the coil.
Go to page 20 of the manual I send you the link for. It says there do not solder.
SmokStak Member #28
Old 07-16-2019, 01:13:01 PM
Ok, will do. Thank you.
Old 07-16-2019, 06:44:03 PM
Ok but the original Q is still what do you use to insulate this terminal? And I do appreciate your patience.
Old 07-16-2019, 08:07:35 PM
Mike in NC's Avatar
None of the Briggs engines I have taken apart had any kind of sealer on the sparkplug wire at the coil.
SmokStak Member #28
Old 07-17-2019, 08:18:20 AM
Tracy T Tracy T is offline
if you have to have some insulation there, silicone should work just fine just dont get carried away with it or you will have a mess!
Old 07-17-2019, 07:48:46 PM
Ok, I tinned the new lead and installed the hopefully good armature. Both were soldered, but not now. I checked the point gap and I needed to get some chalk which I now have and tomorrow I'll check clearances.
Old 07-18-2019, 04:51:00 PM
We have ignition! Now on to the carb and fuel tank!
Briggs Model Y Spark Plug Wire Cnew Small Air Cooled Gasoline Engines 3 11-18-2018 02:19:48 PM
Briggs WMB Spark at Wire but Can't See Spark at Plug KubotaDiesel Small Air Cooled Gasoline Engines 15 05-05-2014 11:15:05 AM
Briggs WI Spark Plug and Wire Zim Small Air Cooled Gasoline Engines 7 03-20-2011 01:19:40 PM
Wire / Coil Insulation Hank Czerwick Magnetos, Ignition Coils and Spark Plugs 5 07-29-2008 03:13:36 PM
