Cushman Scooter Wico 12 volt magneto wonít 🔥
this thread has 3 replies and has been viewed 301 times
Old 07-18-2019, 08:40:57 PM
DTurner DTurner is offline
Default Cushman Scooter Wico 12 volt magneto wonít 🔥
Any body an expert on these magnetos ❓Asking for a friend. I talked it over with him, I canít seem to think of anything heís done wrong?
Itís wico 12 volt new ignition coil with 12 volt headlights coil and six volt taillight coil.
He trying to bench start before he put into the scooter.
We did a test of the points condenser with d cell and it fires.
Resemble and use flywheel nothing .
The headlight and tail light coils are not on armature for bench test .
What else ❓🤷_♂️
Oh the magnets are alternating north and south.
The coil armature is about .017 from magnets
Checked mechanical timing .
A tech at carpenters said the magnet 🧲 are strong enough from what he explained how to test magnets
Just have no idea whatís wrong ❓
Old 07-18-2019, 09:25:22 PM
Geikenr49 Geikenr49 is offline
Default Re: Cushman Scooter Wico 12 volt magneto wonít 🔥
I had a similar issue with a 4 hp Cushman. The problem was Grounding. What I had to do was run a tap through the head bolt holes where the shroud bolts go. Just needed a good ground for the plug to fire.
Old 07-19-2019, 07:20:23 AM
cobbadog cobbadog is offline
You could also try closing the gap down to 0.012" - 0.010". It is always a good idea to check and confirm all wires both earth and live but if you are hot off the battery then earth maybe ok.
Re-gap the coil and try that. It would be rare you have lost too much magnetism in the flywheel as I have flywheels here from mid 1950 off some old mowers and they are still strong but it certainly is worth making sure they are strong enough. For me I just drag a srewdriver shaft across the magnet and if it sticks it should be good enough to make a spark.
Hope it works for you so let us know how you get on.
Old 07-20-2019, 09:39:14 AM
is the point cam on the right direction?correct point cam for your rotation directio?turning engine correct direction?triple checked wiring?
Cushman Vin Step Thru Scooter Rozza720 Butt Buggys, Scooters, 4 Wheelers 7 10-18-2018 08:15:08 AM
4HP Cushman w/Wico Magneto sjaysop Hit & Miss Gas Engine Discussion 2 08-02-2015 01:00:18 AM
cushman highlander scooter bill shields Antique Motorcycles 2 07-07-2014 06:18:12 PM
Cushman scooter engine brew56 Small Air Cooled Gasoline Engines 4 11-25-2013 01:17:40 PM
Cushman Scooter? Handiman Butt Buggys, Scooters, 4 Wheelers 6 08-25-2012 05:21:08 PM
