Monitor 1 1/4hp & 2 1/2hp
this thread has 74 replies and has been viewed 13694 times
Old 09-19-2009, 11:30:10 PM
Jerry B Jerry B is offline
Default Monitor 1 1/4hp & 2 1/2hp
I just got this monitor 2 1/2hp, VJ Model 43381, Can some one tell what year it is, I needs to be rebuilt, The mains or real lose,Or there some one that can help me. I my of give to much for it i give 500 for it. Jerry B
Old 09-20-2009, 08:30:43 AM
George Arney's Avatar
George Arney George Arney is offline
Default Re: Monitor 2 1/2hp
Jerry , I don't think Monitor made a 2 1/2 hp engine. If it has a single flywheel it's likely a 1 1/4hp. From your serial # it was probably built in the latter part of 1933 or early 1934. If it's the 1 1/4 hp there will be paper shems under the main caps . If it's not worn too bad you can remove some to tighten it up.
George Arney
arney7@yahoo.com
The Following User Says Thank You to George Arney For This Post:
Old 09-20-2009, 09:45:28 AM
Joseph Cissell Joseph Cissell is offline
Jerry, If you got one flywheel, then it is a 1 1/4HP Monitor engine for pumping water and if you got 2 flywheels, then you have 2HP monitor engine or larger. Joe
The Following User Says Thank You to Joseph Cissell For This Post:
Old 09-20-2009, 02:14:19 PM
Default Re: Monitor 1 1/4 hp
Is it hard to replace the mains, And do they make a book on rebuilding the engine, It don't have the pumpjack on it are they hard to find, Jerry B Think you
Old 09-20-2009, 09:58:03 PM
Jerry ,
here is a link to a complete Monitor rebuild.
http://www.oldengine.org/members/hol...humbnails.html
Old 09-22-2009, 10:35:39 PM
Default Monitor 1 1/2hp
Help, are there a way to get the keyway out of the flywheel,I have drilled it about 1 3/4'' and tap it with a 1/4'' tap, And heated it to and made a puller it will not move, Jerry B
Old 09-26-2009, 09:19:16 PM
Default Monitor 1 1/4 hp
Does anyone have parts for my engine, I need the big gear that runs off the crank, Jerry B
Old 09-26-2009, 09:39:02 PM
rusted rusted is offline
I may have one on one of my parts engines. Will try to check tomorrow. Send me a PM and I'll send you back a picture if I have one.
The Following User Says Thank You to rusted For This Post:
Old 09-26-2009, 10:26:57 PM
Are you guys talking about the large gear for the pump jack??
Jim
Old 09-26-2009, 11:11:02 PM
I need the big gear that runs off the crank up to the shaft that runs the cam Jerry B
Old 09-27-2009, 09:40:41 AM
Brickman's Avatar
Brickman Brickman is offline
i dont have the gear but do need a flywheel for one thanks ron brown in central illinois
Old 09-27-2009, 07:21:47 PM
I didn't get a reply
Old 09-27-2009, 11:10:56 PM
Grape Grape is offline
I've got some parts thanks to old Iron Jeff. I got them cheap. I'd feel like I'm cheating him if I sold them for a lot of money so It won't cost much. The problem is getting them off the shaft. I don't have access to a torch for heat right now but if your not in to much of a hurry or can't find one anywhere else. Give me a PM. I'm looking for a few Monitor top ends. cylinder and water hopper. Anyone have some of them laying around???
Phil Grape
Remember, to Belittle others is to Be Little yourself
Old 09-27-2009, 11:13:00 PM
Ron, I might have a flywheel for you too.
Phil Grape
Old 10-01-2009, 09:54:11 PM
You do have the gear, It is the big gear that runs off the crank, It is about 8'' or so Jerry B email powdergunman@yahoo.com
Old 10-01-2009, 10:16:21 PM
I have a good crank gear but I need the big gear that runs off the crank , the gear is about 8'' or so, If you have one you can call collect Jerry B email powdergunman@yahoo.com
Old 10-05-2009, 10:13:20 PM
Replaceing the cam bearings I know you can't get the long bearing, So if I put two bearings in how do they get oil, One more question when you pore the mains how do they get oil Jerry B
Old 10-05-2009, 10:23:28 PM
Sam Hamilton's Avatar
Sam Hamilton Sam Hamilton is offline
Other than the drip oiler for the cylinder, I think all the lubrication on the inside of a monitor is splash, so you need to carve some crude oil channels in the bearings.
The Following User Says Thank You to Sam Hamilton For This Post:
Old 10-06-2009, 11:10:26 AM
Harry's old engine , You said putting seals in the cam shaft what kind of seals and do they go on the out side or the inside. Think you Jerry B
Old 10-06-2009, 12:48:56 PM
How do I get Harry's old engine email or website JERRY B
Monitor 1 1/4hp Jerry B Hit & Miss Gas Engine Discussion 0 10-30-2009 09:16:26 PM
3hp Monitor Age T.R.W. Hit & Miss Gas Engine Discussion 0 04-22-2007 11:12:46 PM
Monitor 11/4 Help Charles Hit & Miss Gas Engine Discussion 1 09-14-2005 10:02:17 PM
