Briggs 5S Crank Bushing..?
this thread has 5 replies and has been viewed 2101 times
Old 05-28-2011, 11:04:19 AM
Skirouled Skirouled is offline
Default Briggs 5S Crank Bushing..?
Hi guys, I'm new to the site and I've run into a problem while tearing down my 1950 5s for restoration. When I removed the crank out, I somehow destroyed the PTO side bushing. I used some light pressure with a hammer, but I wasn't really pounding on it. It's all chewed up and I can't even get the crank back in it. Are these things reproduced at all, are am I just out of luck? Oh yeah, this is my first engine restoration
Old 05-28-2011, 11:45:01 AM
Farmboy1 Farmboy1 is offline
Default Re: Briggs 5s Crank Bushing..?
Well if it cant be fixed i have quite a few 5s blocks that are all good, that we can arrange for you to get ahold of.
Old 05-28-2011, 12:18:48 PM
K D Redd K D Redd is offline
Part Number is 89667. I do not know if still available. It could be made if you know someone with a lathe. It needs to be reamed in place once installed.
Kent
Old 05-28-2011, 12:35:22 PM
Jerry Jerry is offline
I have a NOS Bushing Part Number 89677 in stock, PM me and I can hook you up....Jerry
The Following User Says Thank You to Jerry For This Post:
Old 05-28-2011, 02:00:24 PM
Exclamation Re: Briggs 5s Crank Bushing..?
Check your crank for rust, galling, wear, near the bearing. Even very small burrs can ruin the bearing, Look especially where the oil seal rides - sometimes oil seepage attracts dirt and debris, which then will tear up the bearing when you remove the crank! If it is crudded up, ckean with a jewelers file and some 300 or fined emory paper. oil the crank well when re-installing. Also be careful of the timer plunger! Remove it before re-installing the crank!
Old 11-14-2011, 09:26:20 PM
Coleslaw Coleslaw is offline
Talking Re: Briggs 5s Crank Bushing..?
I am in the process of restoring my 57 5s as well. luckily the inside looks almost new and will need very little work. I will need a new oil seal though since I noticed some oil behind the points plate, and the governor arm is bent up. anyone have these? I would be interested in purchasing.
Briggs crank specs brew56 Small Air Cooled Gasoline Engines 0 06-23-2011 08:26:42 AM
Crank for a Briggs model A Johnnyboy Small Air Cooled Gasoline Engines 23 04-29-2011 12:06:08 AM
Briggs crank starting ... KidDynamo Small Air Cooled Gasoline Engines 11 12-30-2009 05:54:10 PM
Briggs Crank Question Jimmy Small Air Cooled Gasoline Engines 5 12-28-2009 07:51:45 PM
Guide Bushing & Reamer work for a Briggs James Wallace Small Air Cooled Gasoline Engines 14 01-07-2008 10:43:28 AM
