Easy Engine Oil Pump Question
this thread has 5 replies and has been viewed 683 times
Old 03-25-2019, 05:48:32 PM
JF671 JF671 is online now
Default Easy Engine Oil Pump Question
Greetings All,
I started fussing with an Easy engine, that appears to be capable of running, except that oil pours out from a missing plug or check valve in the lower part of the rear crankcase cover almost as fast as it's poured into the engine. I removed the plug form the right side to see what lived in there, which turned out to be a spring and a check valve/plug. Am I missing a similar set up for the left (as shown in the pics) side, or is something else going on here?
Thanks in advance for the help!
John
Name:	EASY MISSING PLUG 2.jpg
ID:	331362   Click image for larger version
Name:	EASY MISSING PLUG.jpg
ID:	331363   Click image for larger version
Name:	EASY CHECK VALVE.jpg
Old 06-22-2019, 08:24:06 PM
pigpen60 pigpen60 is offline
Default Re: Easy Engine Oil Pump Question
Are the threads the same as the one with the checkvalve? I see the pipe plug and wonder why would the company drill a hole and then put a pipe plug in?
The Following User Says Thank You to pigpen60 For This Post:
Old 06-23-2019, 06:28:31 PM
What I meant on the plug is what was its use? A gauge maybe? what would be the benefit of a check ball on the side without? Just talking it out to see if someone will have that Eureka moment.
Old 06-25-2019, 10:49:34 AM
The plug is interchangeable to either side. The engine was apparently pressure lubricated, with the check ball figuring into the system somehow. I was hoping that I wouldn't have to crack 'er open to sort things out here, but that's not out of the question. Worst case, I'll see about fitting a dipper which would probably do a better job of keeping things wet than the pump did .
Old 06-25-2019, 11:41:31 PM
Bob Whitney Bob Whitney is offline
JF671 I have a ruff drawing of the oiling system that I made about 35 years ago. If you have an oil pump failure the main bearing on flywheel side will seize.
Bob
The Following User Says Thank You to Bob Whitney For This Post:
Old 06-26-2019, 10:11:13 AM
Thank you! That's exactly what I was looking for!!
Easy engine carb question Spenser Rynne Small Air Cooled Gasoline Engines 1 01-13-2019 09:59:41 PM
Onan JB: An easy question for you JB experts allantollett Onan Generators 11 12-13-2013 10:20:50 PM
Dead easy air pump Pyeper Farm Antiques and Collectibles 2 04-25-2007 06:00:17 AM
Easy Wico Question Jim Young Antique Engine Archives 2 10-20-2004 04:08:25 AM
Easy Washing engine question kelly Barnett Antique Engine Archives 2 12-08-2002 11:10:10 PM
