Steam Engines
Scale Models 1/4, 1/3, 1/2, ect
this thread has 387 replies and has been viewed 84181 times
Old 03-14-2019, 05:27:06 AM
b7100 b7100 is offline
Default Re: Scale Models 1/4, 1/3, 1/2, ect
Thought I would add a couple of a new model
ID:	330589   Click image for larger version
Old 03-15-2019, 09:26:25 AM
Casemaker Casemaker is offline
Jeff,
look at a 1/3 scale Case flywheel should be about right size.
Old 03-16-2019, 03:49:49 PM
Jeff Searson Jeff Searson is offline
Hello Casemaker.... is there a website, Facebook profile or name you could steer me in the direction towards?
Old 03-16-2019, 05:20:44 PM
Reduction engineering in Beulah Montanna has the 3d scale castings. It is going to be tuff finding anything that will have exactly what you want. You might consider a piece of thick wall tubing and try to find a 6 spoke wheel and cut the rim off. That would get you closer to what you want. You can get the tube most any size you want and 3" don't seem like it would be that much. Finding a wheel might be a little harder.
---------- Post added at 17:20 ---------- Previous post was at 17:04 ----------
Ebay has some heavy cast iron gears that might be perfect. If you could find the right one just turn the teeth off and shrink a piece of tubing on. It would be real close to what you want.
Old 03-16-2019, 09:40:27 PM
LarryT LarryT is offline
The drawings for the 1/3 scale case shows the flywheel as 12 1/2" diameter, 4 3/16 wide and has 6 spokes. Reduction Engineering sells the castings, as the earlier posting points out. LarryT
Old 03-16-2019, 10:52:28 PM
Reduction's casting is actually around 13 1/2". Maybe close enough?
Old 06-15-2019, 08:33:30 PM
Nick Severson Nick Severson is offline
Looks to be a 1/6, anyone here the lucky new owner?
Name:	Screen Shot 2019-06-15 at 7.27.54 PM.png
Old 06-30-2019, 01:12:35 PM
Pictures of models sold on discoverlivesteam.com
ID:	338238   Click image for larger version
ID:	338239   Click image for larger version
ID:	338240   Click image for larger version
Old 06-30-2019, 01:16:00 PM
More of same..
ID:	338242   Click image for larger version
ID:	338243   Click image for larger version
ID:	338244   Click image for larger version
Old 06-30-2019, 01:19:33 PM
A large case model....
Old 06-30-2019, 01:22:26 PM
Old 07-10-2019, 08:23:31 PM
Old 07-10-2019, 11:14:50 PM
https://www.youtube.com/watch?v=1QaerMUkYq4
Old 07-16-2019, 11:02:59 PM
https://www.youtube.com/watch?v=m941c9LKM_Y
https://www.youtube.com/watch?v=EdgPjEjNkVk
Old 07-16-2019, 11:18:38 PM
Originally Posted by casertractor View Post
Ron Colonna has built some of the nicest scale engines and his one-inch Case is a favorite of mine at NAMES. I took this a few months ago
Old 07-17-2019, 08:37:00 AM
https://www.youtube.com/watch?v=mEZ7EmmppTE
Old 07-17-2019, 05:28:28 PM
This one is what started my interest in scale models many years ago
Name:	Wayne Lowdon Scale Engine Milton Steam Era.jpg
Old 07-19-2019, 10:26:36 PM
1/2 Scale at Root River (Racine, MN) today
Old 07-20-2019, 06:43:36 PM
Jim Conte's Avatar
Jim Conte Jim Conte is offline
Roughly 1/8 of the full size engine. All dimensions are 1/2 of the original, length, width, height. Scale down the cylinder 1/2 the height x 1/2 the width x 1/2 the length. 1/2 x 1/2 x 1/2 = 1/8 :-)
http://www.boilersaver.com/
Old 07-20-2019, 07:28:56 PM
https://www.youtube.com/watch?v=vhHyTiNidwg
Scale Models at Nowthen, MN '17 Nick Severson Scale Model Engineering 4 08-29-2017 10:05:12 PM
Scale Models -vs- Representations Jeff Smith Scale Model Engineering 7 01-25-2015 03:33:59 PM
Scale models / where are they now? Robert M Steam Stationary Engines, Traction Engines 22 07-18-2008 10:36:03 PM
Ihc Famous & R&v Scale Models Edwin Scale Model Engineering 1 01-02-2007 11:03:47 AM
Hartland Scale Models Wayne Lowdon Steam Stationary Engines, Traction Engines 5 02-28-2005 01:49:29 AM
