1965 Jacobson Briggs
this thread has 5 replies and has been viewed 587 times
Old 07-20-2019, 02:59:36 PM
Subzero97 Subzero97 is offline
Photo 1965 Jacobson Briggs
Hi everyone, I’m still working on restoring my 1952 Clinton I posted about prior but as I’m sure with others new projects seem to find their way home from time to time. Today I found a 1965 Jacobson Victor 21 reel mower the seller said was a 1965 model. It looks original and complete and only require minor work to run. I’ve always wanted an old reel mower and this ones looked like one of the nicer ones I’ve seen in my area so $100 later it was mine. What kind of Briggs is on this and is there any work I should check into on the mower mechanics before attempting to use it?
ID:	339492   Click image for larger version
ID:	339493   Click image for larger version
The Following 4 Users Say Thank You to Subzero97 For This Post:
Old 07-20-2019, 10:50:28 PM
John Newman, Jr.'s Avatar
Default Re: 1965 Jacobson Briggs
Look for numbers stamped in the blower housing. I can see them next to the decal showing in the first picture.
You should find Model, Type and either Serial or Code numbers.
Model and Type will let you find manuals and IPL for your engine.
If it has a Serial Number, you will have to refer to a list (available on this site) to determine when it was made.
If it has a Code Number, you can read the date directly. YYMMDDxx
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 09-06-2019, 09:11:42 AM
Benjamin Gradler Benjamin Gradler is offline
This is older than 1965. It could be as old as about 1959. Most of the aesthetic features of this engine were phased out in the early 1960s.
The Following User Says Thank You to Benjamin Gradler For This Post:
Old 09-06-2019, 08:13:12 PM
Ogrebeast64 Ogrebeast64 is offline
This looks like a Briggs 6S to me.
Old 09-06-2019, 08:43:08 PM
I am going to say it's a Briggs model 6B going on the looks of it.
Old 09-06-2019, 10:19:29 PM
A 6b would have a plate on the engine that says "6B", if there is no plate then it would be a 60000 series engine or an 80000 series engine from about 1959 or later. The early 60000 and 80000 engines looked identical to the previous 6b and 8b engines externally, but Briggs began to change things inside first, such as they dropped the valves with pin-valves, keepers and retainers and went to the regular wedge-style valves, retainers and keepers. The old three-leg ignition coil was ditched soon too.
Briggs model 8 (i think)coil needed, 1965 ? mschreiber Small Air Cooled Gasoline Engines 8 07-19-2017 10:06:45 PM
1965 parkmaster 7 1965 parkmaster 7 Garden Tractors and Mowers 0 06-29-2009 11:51:10 PM
1965,Hollingsworth,3kw Patrick Drisccoll Generators & Electric Motors General Discussion 0 09-02-2003 03:48:35 PM
