Briggs and stratton "A" price Q
this thread has 15 replies and has been viewed 718 times
Old 07-20-2019, 09:52:19 PM
pigpen60 pigpen60 is offline
Default Briggs and stratton "A" price Q
So what would an A with good compression but not running missing the starting crank be worth? Is there a "Blue Book" for old engines?
The Following User Says Thank You to pigpen60 For This Post:
Old 07-20-2019, 11:13:52 PM
John Newman, Jr.'s Avatar
Default Re: Briggs and stratton "A" price Q
Iíve got a couple like you describe. Early models brass tags. Pre FloJet. Last time I went to Portland I had them marked $40 for the rough one with no tank. $60 for the better one with a dented tank.
Had to bring them back home.
Interested? PM me.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
The Following User Says Thank You to John Newman, Jr. For This Post:
Old 07-21-2019, 09:51:42 AM
At the moment I'm trying to figure whats worth what but I'll keep you in mind.
Old 07-21-2019, 10:58:29 AM
grega's Avatar
grega grega is offline
Images: 106
Need more information to give an accurate price there are a lot of variations in the A series. Assuming itís a plain A in good shape but with no unusual features probably $40 for one with the flow jet carb, $75 if it has the early carb.
"There only origionial once"
The Following 2 Users Say Thank You to grega For This Post:
Old 07-21-2019, 07:45:15 PM
What does the early carb look like?
Old 07-22-2019, 10:58:43 PM
I forgot to take a picture of one when I was at my shop today, but here is the page from the IPL for the 5-digit type Model A.
5-digit type will have this carb and a brass tag attached to the blower housing and a cast iron gas tank bracket.
6-digit type will have a Flo Jet carb and an aluminum tag riveted to the tin cylinder air shroud and a stamped gas tank bracket.
Here are pictures of the 5-digit type carbs. One is a B&S carb and the other is a Tillotson as noted in the IPL
Name:	Model A Carburetor.jpg
ID:	339710   Click image for larger version
ID:	339739   Click image for larger version
John Newman, Jr.
Saint Louis, MO
The Following 3 Users Say Thank You to John Newman, Jr. For This Post:
Old 07-23-2019, 10:17:59 AM
"IPL"?
Old 07-23-2019, 11:16:15 AM
Illustrated Parts List
John Newman, Jr.
Saint Louis, MO
Old 08-09-2019, 06:03:52 PM
Here is a pic of the carb and whats left of the exhaust. While we are looking does the A have a threaded exhaust port?
Name:	A exhaust.jpg
The Following 2 Users Say Thank You to pigpen60 For This Post:
Old 08-10-2019, 10:55:54 AM
Yes. It has pipe threads - 3/4 NPT, I believe.
Looking at your picture, it will probably be a challenge to get whatís left out. A common method is to grind or cut lengthwise inside the pipe stub just until you see the threads showing. A Dremel or die grinder with a small diameter stone or a carbide rotary file works well. You can also use a hacksaw blade, but takes more time and effort. Once you get it down to the threads you should be able to collapse the pipe with a pair of Channelocks pliers and remove it.
John Newman, Jr.
Saint Louis, MO
Old 08-10-2019, 04:43:07 PM
Where did you find the IPL?
Old 08-10-2019, 06:01:35 PM
Well, most recently, in my file cabinet.....
Seriously, I probably got it through Ebay. Many years ago. Fortunately I have both the 5 and 6 digit Type IPLs in my archives.
I regularly looked for relevant manuals and IPLs for the engines that I have. Still do, but not as much anymore.
Name:	Model A IPL.jpg
ID:	341145   Click image for larger version
Name:	Briggs A 5 digit IPL.jpg
John Newman, Jr.
Saint Louis, MO
Old 08-10-2019, 06:15:46 PM
One more thing I'll need to look for.
Old 08-10-2019, 08:53:03 PM
Duey C Duey C is offline
This thread spurred me to go look at my 5 digit A with Tillotson carb. Now I know some more about it. Thanks pigpen!
Shoot, I'm just gonna ask. John, would you be willing to share all of that parts book?
The Following User Says Thank You to Duey C For This Post:
Old 08-10-2019, 09:08:29 PM
gdstew gdstew is offline
I went to Google and typed in "antique briggs and Stratton manual" and came up with this
https://www.briggsandstratton.com/na...fications.html
The Following User Says Thank You to gdstew For This Post:
Old 08-10-2019, 09:51:53 PM
I have not had a working scanner in some time. Not true. My old scanner probably still works, but it won't communicate with the new computer. 16 bit vs 32 bit, or something like that. Guess I should break down and buy a new one...
Best I can do these days is take a picture with my phone. Would like to learn how to make a PDF for this stuff to be able to share easily.
John Newman, Jr.
Saint Louis, MO
Briggs and Stratton Twin 18 1/2 Cast Iron Bore "L" Head PhoenixRising2015 Small Air Cooled Gasoline Engines 2 07-31-2016 10:40:17 PM
Briggs & Stratton Motor Wheel powered "Hersey" Scooter barnhunter Unidentified Engines 4 12-27-2013 06:04:15 PM
Early Briggs Stratton "Y" with "X" in type number mschreiber Small Air Cooled Gasoline Engines 7 05-14-2012 09:33:34 PM
Briggs and Stratton "A" on 1934 Locke Rotary Mower - An early A? ArtInCONN Small Air Cooled Gasoline Engines 22 12-25-2011 11:45:24 AM
Briggs and Stratton Models "T" and "W" Tom Schaech Antique Engine Archives 0 10-13-2003 09:12:44 PM
