Go Back   SmokStak > Other Vintage and Antique Collectibles > Antiques for the Home > Vintage Toy Steam Engines and Motors
Vintage Toy Steam Engines and Motors Weeden, Empire, Doll, Jensen, Wilesco, Mamod, Marklin
1/4 scale 1978 Rider Hot Air Engine Kit
this thread has 15 replies and has been viewed 3138 times
Old 05-31-2016, 12:29:53 PM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
Default 1/4 scale 1978 Rider Hot Air Engine Kit
hello all. i have recently got an old hot air engine model from a friend. dated 1978 , castings and prints by norbert keeley ohio. he did tell me it was missing some parts. i had the time to check everything out and it looks im missing the firebox,firebox door and the water pump? i have the drawings for everything. was wondering also if these kits were sold possibly with a gasket kit? i would assume these models can only be used with natural or propane gas? would anybody or staker out there have spare parts around for this that i need? maybe best i call Myers models to see if they sell these parts?
ID:	255190   Click image for larger version
ID:	255191   Click image for larger version
Old 05-31-2016, 01:51:53 PM
Heller D. Davis Heller D. Davis is offline
Default Re: 1/4 scale 1978 rider hot air engine kit
The firebox and door, you can order from Myers Models. The water pump will have to be made by you or someone else.
The Following User Says Thank You to Heller D. Davis For This Post:
Old 05-31-2016, 07:24:19 PM
Dave Otto Dave Otto is offline
On an engine that old, the firebox and door would have been fabricated. You should have drawing that shows all the parts and the flat pattern for the sheet metal. There was a pretty good article in the book Steam and Stirling (Village Press) that showed the firebox fabrication.
As Heller indicated you can probably purchase the cast aluminum parts from Myers. I'm not completely sure; but think the fire box castings were something that Clarence Myers did after he took over the engine from Norbert Kelley.
Dave
The Following User Says Thank You to Dave Otto For This Post:
Old 06-03-2016, 11:25:49 AM
made contact with myers with the parts im missing they were able to help me.
The Following User Says Thank You to Firewoodguy For This Post:
Old 07-06-2016, 07:14:11 AM
started the 1/4 scale project. the norbert kelley castings not too bad. just my tooling is from the 1940s. the 12" regal isnt no cadillac.. but still gets the job done.
ID:	257738   Click image for larger version
ID:	257739   Click image for larger version
ID:	257740   Click image for larger version
Old 03-08-2017, 10:42:50 PM
Gil Garceau Gil Garceau is offline
Your work looks real good so far.
Is that flywheel aluminum like on the newer ones.
Mine was built by Kent Smith in 2002.
Gil
My youtube channel: http://www.youtube.com/user/reddrryder/videos
Old 08-28-2017, 07:09:05 AM
Default Re: 1/4 scale 1978 Rider Hot Air Engine Kit
Any more progress on your Rider Ericsson model?
The Following User Says Thank You to Gil Garceau For This Post:
Old 08-29-2017, 06:45:59 PM
Gil, the flywheel is cast aluminum. The engine is just about 1/2 finished. I put it to the side right now with my summer projects going on. Will post pics when I'm down the homestretch. Shawn
Old 08-29-2017, 06:55:07 PM
Thanks, Shawn. Looking forward to updates when you can get back to it.
Old 02-21-2018, 10:18:04 AM
we had some time to tinker with the 1/4 scale. had a problem, was cleaning of the work table and accidentally dropped the walking beam! well, it broke! Didn't know what to do, called Myers and they helped me big time! I was fortunate enough that they had a spare walking beam to send me.
The Following 2 Users Say Thank You to Firewoodguy For This Post:
Old 02-21-2018, 03:31:56 PM
That must have been some fall! I didn't realize that that casting was so brittle Andrew dropped my engine and bent the hoop that goes from the cylinder to the flywheel (BOO HISS). Will try and straighten it out. See you at Jacktown??? Mr Smith - the Woodpecker guy built mine. was POed he couldn't get it to run for more than a minute or so, at a time. I hooked the pump up to a water supply, and it ran fine. He was even more POed after that! I got it relatively cheap because for him, it didn't work!
On mine, I took a PEAK camping propane stove burner and modified it so that a hose could be hooked to a propane regulator from a Coleman stove. flame height could be regulated from there. The burner was mounted under the hot section on the engine, inside the fire box. The chimney was made of a copper 3/4" ell and a 1' piece of 3/4" type L copper tubing, painted high heat grill black (semi gloss) If you make your own check balls for the pump, make them out of Teflon or brass. John made mine out of steel, and if I let the engine sit a while, I have to take it apart to free the check balls up! You probably could get them already made from Lee Pederson, if you have the diameter. lee has a selection of checkballs. For a cooling reservoir, I used a brass tank (capacity about 1 Qt, and a home made radiator, made out of 1/4" copper tubing and some copper wire for heat disapation.
Old 02-23-2018, 07:40:50 AM
Andrew. yeah, you really wouldn't think that the walking beam casting was that brittle to break. It had to fall on a spot that was 1 in a million. lol. Thanks for the check ball info. Hope you get the hoop fixed on your engine. couple fresh pics. the new beam is done
ID:	303893   Click image for larger version
Old 02-23-2018, 07:42:48 AM
finished shaft for the walking beam. started on the power piston.
ID:	303895   Click image for larger version
Old 03-09-2018, 08:26:21 AM
making of the center power piston
ID:	305010   Click image for larger version
ID:	305011   Click image for larger version
ID:	305012   Click image for larger version
Old 02-21-2019, 05:04:37 PM
displacer piston rod and end.
ID:	329112   Click image for larger version
The Following 5 Users Say Thank You to Firewoodguy For This Post:
Old 03-23-2019, 03:45:17 PM
few more pics to share. slooowy going..
ID:	331192   Click image for larger version
ID:	331193   Click image for larger version
ID:	331194   Click image for larger version
ID:	331195   Click image for larger version
ID:	331196   Click image for larger version
Rider Engine Co. and Rider-Ericsson Engine Co. histories—Information Wanted Brent Rowell Hot Air Engines 15 11-25-2016 08:28:00 PM
Looking for Running 1/4 or 1/2 scale Rider-Ericsson bsatom Hot Air Engines 4 11-25-2011 06:22:17 PM
1978 Ford Skid-Steer with Onan NHC engine will not start! Merc300SD Onan Generators 7 03-26-2011 11:18:03 AM
1/2 scale Kitten Steam engine/1/4 scale case KG1584 Steam Stationary Engines, Traction Engines 9 07-21-2006 12:21:43 AM
Rider/Rider -Ericsson Hot Air Engine ? Andrew Voss Antique Engine Archives 0 06-11-2000 01:38:54 AM
