Go Back   SmokStak > Other Vintage and Antique Collectibles > Antiques and toys for the Home > Vintage Toy Steam Engines and Motors
Vintage Toy Steam Engines and Motors Weeden, Empire, Doll, Jensen, Wilesco, Mamod, Marklin
Toy steam engines run on compressed air help please
this thread has 19 replies and has been viewed 4394 times
Old 07-18-2016, 03:37:42 PM
R. Kern's Avatar
R. Kern R. Kern is offline
Default Toy steam engines run on compressed air help please
I've got a nice collection of Empire toy steam engines and most run on their own live steam (electric built in heaters) but I have several that have the heaters burned out and I'd thought I'd try and set up 3 or 4 to run on compressed air from some sort of 12Volt pump so I could "hide" the pump and run them on compressed air at engine shows. I know I can buy electric heating units and again I got many running steamers...this is for something different.
I'm older and heavy stuff is a problem...figured if I put a 12 volt battery in my trunk and used it to power the compressor to run the engines it might be fun and not too much work.
My questions are has anyone done this with small engines? I know some folks run larger steam engines on compressed air but these are just toys....I'm guessing 5 psi or so might run them. Should I use a manifold with one pressure gauge or do I need some sort of gauge for each outlet and engine?
Finally is there some compressor that can be used that is not noisy like a tire pump?
I'd bet someone has done some of the ground breaking and if they want to share some of the pros and cons it would be much appreciated...thanks again
R. Kern
Old 07-18-2016, 05:30:42 PM
Default Re: Toy steam engines run on compressed air help please
There are commercial compressors that work on 12 volt. They are made to maintain brake pressure on trucks that stand idle for extended time - like fire trucks. These pumps are not cheap! you might be better off looking for a good sized inverter and an old style paint compressor, that only puts out about 30 PSI. Either way, it will take a lot out of your battery to power the compressor. Even those little tire pumps take up to 10 amps, and they tend to overheat if used for over 3 or 4 minutes. I know, as I tried it! An alternative is to mount an old compressor to a small engine, like a B&S 5-S. At idle, it will be quiet, make enough air for your models, and makes a light, quiet neat display all on its own! better than running your truck to keep the battery up!
As for engine pressure, 5 to 10 Psi should do it. Install regulator at supply end of a manifold, and install individual shut off valves for each terminal from the manifold (each engine). The regulator will maintain the pressure up to the limit of demand and supply, and each engine can be 'throttled' with its supply valve. NOTE - your steam engines, run on air, will not be efficient, as there will be no expansion to do the work. The engines will be less powerful and will waste a lot of air
Old 07-18-2016, 05:46:09 PM
G.M.Johnson G.M.Johnson is offline
How long do you plan on running your little steamers, Short bursts to show spectators that stop by, or for many hours? I don't see why your idea wouldn't work. Maybe take a couple of batteries, instead of one, hook your compressor up to a small receiver air tank, but them both in the trunk, run a air line out to the manifold, and split off from there to each motor? Most 12v compressors are of the noisy type and putting it in the trunk would muffle the noise, but then how long before your battery runs down. As far as a manifold goes you can make a simple one out of black pipe fittings and a single gauge should be fine, no need for individual ones. Being in the HVAC trade, I myself have used a small high pressure tank of dry nitrogen, regulated down to what ever pressure I want and have used this as a source for air. I also have friends that are big into the air rifles and use filled scuba tanks as well, which are a lot lighter and can go a lot higher in pressure which yields more capacity. Nitrogen tanks in all sizes you can get and rent on exchange bases at any HVAC supply house. As far as scuba tanks go, some scuba shops are picky and don't like to fill tanks without being a licensed scuba diver. Mine where I live don't care either way. Just a few ideas.
Old 07-18-2016, 05:56:24 PM
joncrane joncrane is offline
I run my model engines off a sears compressor,110v and an extension cord. Can usually find an electric hookup "no too far away'.
Saw another guy run his smaller toys with an air compressor from a fish tank bubbler. Really small and he hooked it up with plastic 1/ hose. Again he plugged it in. Bubbler compressor probably did not weigh two pounds and was cheap too.
Old 07-18-2016, 06:40:52 PM
BobSaunders BobSaunders is offline
Here is my set up at shows. The manifold is ice maker valves from Menards. Paint sprayer pump. No need for a gauge. I also use fish aquarium valves when needed. I have a air pump for an azimuth or medicine inhaler from a thrift store for $5. 3 lbs is about right. Bob
ID:	258473   Click image for larger version
ID:	258474   Click image for larger version
The Following User Says Thank You to BobSaunders For This Post:
Old 07-19-2016, 10:24:04 PM
R. Kern's Avatar
Many thanks to everyone that chimed in....I got some ideas and will proceed to figure out what works...be an interesting experiment...I'm to the point that the bit cast iron hit and miss are getting way to heavy to keep messing with...
One thing I'm going to try is to use a really good running Maytag twin to run a small compressor...the Maytag is really clean burning so very little smoke and it's got a great muffler system on it so it's nice and quiet...might be a way to run a small compressor and have the best of all worlds..an antique gas engine and some antique steam toys...all in one display.
Thanks again
R. Kern
Old 08-03-2016, 09:24:37 PM
John Hamilton's Avatar
John Hamilton John Hamilton is offline
Those really small compressors that plug in to a cigarette lighter work fine. Just use a quick release on the hose and engine to make easy work of it. Probably Walmart or Harbor Freight have just the thing.
Old 08-05-2016, 07:33:48 AM
Gil Garceau Gil Garceau is offline
As pointed out above, small Briggs style 4 cycle engines at slower speeds are nice and quiet.
A long 1" to 1.5" ID reinforced plastic hose works great to get the air supply near your display
and acts as an air tank at the same time, thus eliminating pulses from your display.
My youtube channel: http://www.youtube.com/user/reddrryder/videos
Old 08-05-2016, 08:27:19 AM
Odin Odin is offline
A display I've seen a few times has model engines for sale all running off of compressed air.
They use a small modern engine driving what looks like a 5 gallon compressor. There's a regulator between the compressor and manifold to give a constant pressure, followed by a smaller tank that I think is actually an old 1lb propane tank welded into a stand containing the manifolds. Each engine has its own needle valve, and is connected by clear vinyl tubing. I guess the air pressure required to make them tick along isn't much at all.
As long as you took care of the engine exhaust, you could probably run a suitable sized compressor without unloading it from the truck. Then wherever you go you'd have power for your display. Maybe get the gas engine to run a compressor as well as an alternator so you have electricity for the electric boilers that still work as well as air for the models that don't have a working boiler to use.
Old 08-09-2016, 08:29:02 AM
kwfiggatt kwfiggatt is offline
You might look up a Gast air pump. These are vane style pumps that run 5~10 psi, used in labs, and also in sewage aerators. Ebay is a good place to look. I've seen them belt driven and direct electric motor drive. New they aren't cheap, but are very rugged.
The one that I have has a bleed fitting on the outlet to control the pressure. I'm using mine on a waste oil burner that used low pressure air for oil atomization.
Old 12-27-2016, 09:16:59 PM
darrelld darrelld is offline
I recently purchased an "Ultra quiet" air compressor from Menards. I intend on using for such purpose. You can actually visit with the compressor running close by. Been making my adapters for Wilesco and Jensen engines, Empire, Weeden and Mamod next. Where do you find replacement heaters for Empires and perhaps a Jensen 45? Darrell
Old 12-27-2016, 10:14:54 PM
Junkologist's Avatar
Here is a place that will custom make heaters to your specs. I know another collector had them make a heater for an Empire engine. I have no experience with them myself.
http://heatandsensortech.com/
Your only option for a Jensen 45 heater repair is to wind a new element with new nichrome wire of the same spec as the original. Many times it's just a bad connection inside that is easily fixed, if you get lucky.
Mike
SmokStak member #146
Old 01-05-2017, 07:41:57 PM
Lead Head
Mini-fridges often use very small compressors, which make great very quiet air pumps. The only downside is they push a lot oil out of the discharge - which would probably be beneficial for your model engines anyways.
Just remember to add some kind of light oil into the intake of the compressor every so often.
Old 01-06-2017, 02:40:42 PM
NAR's Avatar
NAR NAR is offline
R. Kern, Here’s my setup I came up with when I was in 5th grade & wanted something compact & lightweight to take to the shows & run my small steam engines. A Maytag twin with one cylinder used as an air compressor cylinder.
It had a tight-fitting gasket on the back of the compressor cylinder that slid around the back cylinder lip to block the transfer port of the compressor cylinder off from the crankcase fuel & air. Holes were drilled on each side of the cylinder transfer port on the compressor side to pull intake. The exhaust port was also blocked off by a gasket. The spark plug was replaced with an outlet check valve. The oiler was added to help lubricate the compressor side & it also puts oil in the air line to lubricate the steam engines or whatever you’re running with the air.
I ran it like this for years without any problems. The compression (dead volume) space in the compressor cylinder was not changed but it’d still pump up to 65 lbs. or more. I made an adjustable outlet line regular/pop-off safety that can be seen in pic 3 below (the brass piece sticking up by the flywheel). The compressed air line connects to the engine on the backside.
The engine is fairly quiet with the ball muffler & small exit holes. It’s always run nice & steady. With the compressor cylinder blocked off from the crankcase, it’s not robbing the crankcase of the scavenging air & fuel so the power side gets a little more than it usually would, & the compressor gives it a little bit of a load.
-Nick
Name:	maytag compressor1.jpg
ID:	271844   Click image for larger version
Name:	maytag compressor2.jpg
ID:	271845   Click image for larger version
Name:	maytag compressor3.jpg
ID:	271846   Click image for larger version
Name:	maytag compressor4.jpg
http://rowland24.20megsfree.com
The Following User Says Thank You to NAR For This Post:
Old 01-06-2017, 02:42:27 PM
NAR's Avatar
NAR NAR is offline
I also made up fake literature showing that it was an original outfit. This was before photoshop & no computer back then so it’s a little crude; it was done on an old type writer I found in the trash at school. Had a lot of fun with the literature & compressor at the shows.
The last two pics are from 2003; I was curious how the gasket that was blocking the compressor transfer port off from the crankcase was holding up. It looked fine & I could have left it but I decided to make it a little nicer by actually cutting a piece of steel to braze & block the port off from the crankcase. The pics are a little blurry but see pics 1 & 2 below.
For a neat, lightweight, quiet & portable air compressor, this Maytag compressor is hard to beat.
-Nick
Name:	fake flyer resize.jpg
ID:	271850   Click image for larger version
Name:	july 2003a.jpg
ID:	271851   Click image for larger version
Name:	july 2003b.jpg
Old 01-06-2017, 02:56:39 PM
Cool conversion NAR! great job
Old 04-06-2017, 05:23:19 AM
Ohio Farm Ohio Farm is offline
I contacted Heater & Sensor Tech a couple of weeks ago about custom Empire and Weeden heaters. They said they no longer make heaters for toy steam engines.
Weeden Steam said they will have a new supply of cartridge heaters coming soon, for the Weeden 43 &44.
Old 01-14-2019, 02:27:32 PM
Len Spoelman Len Spoelman is offline
What is available in low cost, low volume air supply, 110V, to run several model engines? What pressure and volume is needed? Fish tank bubbler, Air Brush paint sprayer pump?
Old 01-25-2019, 11:26:49 PM
Bump. No answers?
Thanks.
Old 01-26-2019, 12:55:45 AM
Nick Severson Nick Severson is offline
Bump. No answers?
Thanks.
I didn't reply as you asked low cost and low volume, and that's probably not your best option... Air compressors are not something to skimp and save money on...
I would suggest looking at California Air Tools as nobody likes a noisy compressor when running steam engines. I also prefer a 15-20 gallon tank as engines will run several minutes between fills and they're still small enough to haul around. Watch the youtube video at the bottom of the page to hear the difference in sound.
https://www.californiaairtools.com/u...-15020c-22060/
I believe they can also be found at Lowes or Home Depot (can't remember which one)
---------- Post added at 10:36:16 PM ---------- Previous post was at 10:22:29 PM ----------
Smaller/cheaper compressors will work, but as I said above, just not worth it and you'll end up disappointed.
My compressors were packed away and I wanted to run these 3 Stuart BB's before shipping 2 off, so I bought the $56 - 1/3 gallon - 3 HP Central Pneumatic from HF. After coupons it was $35
https://www.harborfreight.com/1-3-hp...sor-97080.html
It had just enough to keep them running at the speed shown below, but that was it and took several minutes to fill. Once I had my compressors home, I dumped the compressor on FB marketplace for $40 and couldn't have been happier to say it go! I used 100 ft of hose to hide it in the deepest, darkest corner of my basement and ran the engines upstairs in the kitchen.
---------- Post added at 10:41:45 PM ---------- Previous post was at 10:36:16 PM ----------
And this was the wife's airbrush/makeup compressor... as you can see, very annoying.
---------- Post added at 10:55:45 PM ---------- Previous post was at 10:41:45 PM ----------
And I know Gil and a few others have been very happy with these old, quiet dental compressors
The Following User Says Thank You to Nick Severson For This Post:
Running A stationary steam engine on compressed air. Good idea or Bad idea ? cerwin Steam Stationary Engines, Traction Engines 9 01-06-2013 11:47:35 PM
Compressed air powered car! Danny J Hit & Miss Gas Engine Discussion 3 05-01-2009 01:08:28 AM
wet compressed air Joseph Musser Antique Engine Archives 14 07-12-2004 03:04:55 AM
Briggs on compressed air Ed Leanen Antique Engine Archives 1 03-07-2002 03:50:07 PM
