Go Back   SmokStak > SmokStak® Antique Engine Community > Oilers, Lubricators and Grease Cups
Oilers, Lubricators and Grease Cups Discussion about collecting and restoring oilers, lubricators & grease cups.
Ring Oiled Line Shaft Bearing Babbitt
this thread has 2 replies and has been viewed 858 times
Old 01-05-2018, 05:05:56 PM
old iron shops old iron shops is offline
Default Ring Oiled Line Shaft Bearing Babbitt
I was just wondering if anybody knows what grade of Babbitt will be used in a line shaft hanger bearing I know they have several different ratios of lead & tin I just don't know which percentages I need
Old 01-05-2018, 06:02:10 PM
Default Re: Ring oiled line shaft bearing Babbitt
There is lead based Babbitt and tin based Babbitt. Lead is cheaper and softer than tin. Any lead based Babbitt will be fine for the lineshaft bearings.
Old 01-05-2018, 06:28:30 PM
OK thanks for the tip now if I can just find some counter shaft hangers and clutches I'll be in business
Babbitt Bearing Help Day Radebaugh Machine Shop and Tool Talk 4 09-02-2015 01:56:41 PM
Bearing Babbitt Dave Richards Machine Shop and Tool Talk 3 01-26-2011 03:14:05 PM
babbitt bearing?? Dan Grace Hit & Miss Gas Engine Discussion 2 07-30-2009 05:37:02 AM
How do you pour a babbitt bearing? MarkP Steam Stationary Engines, Traction Engines 11 08-13-2008 03:15:44 PM
Bearing Babbitt ? Randy Hart Antique Engine Archives 5 02-23-2002 06:13:20 PM
