Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Blacksmithing and Metallurgy
Blacksmithing and Metallurgy Hand-wrought manufacture of metal objects, extracting metals from their ores, or purifying metals and casting useful items from the metals.
Young Metalshaper Looking for More Tools
this thread has 11 replies and has been viewed 1704 times
Old 02-20-2018, 12:15:11 PM
charliesd250 charliesd250 is offline
Default Young Metalshaper Looking for More Tools
Hi,
I知 usually more involved in the small engines area of this forum but the last couple years have led me down the path of coach building and higher end fabrication for automotive. I知 23 years old and have been focusing on tig welding, forging and shaping. Had an intern opportunity that became a full time job and have been taking classes with some shapers such as Peter Tommasini, Richard Mullin and Wray Schelin. I currently have a large english wheel with flats and full radius dies, a tig welder, brake, a couple nice fabrication tables, home built hand held planishing hamemr etc. i知 looking for any hand or power tools related to the automotive/aircraft division of this work. Also, I知 super excited for the Center of Metal Arts moving into the defunct Cambria Iron Works in Johnstown, PA. I値l travel any distance and consider any tools that need TLC. Restoring or rebuilding them is right up my alley. I don稚 have a super star budget but I can make ends meet for the right stuff. Thanks! Here is some of my past work...
Thank You!
Charlie
The Following 8 Users Say Thank You to charliesd250 For This Post:
Old 02-20-2018, 12:29:40 PM
Big Bird Big Bird is offline
Default Re: Young metalshaper looking for more tools
For being 23 years old you have skills that are normally acquired over a long period of time...
I have been beating sheet metal in to submission for the past 25 years and your skills are apparent to me...
Good. Luck in your search for tools,
But remember the best tool in your bag will always be your brain....
The Following User Says Thank You to Big Bird For This Post:
Old 02-20-2018, 12:32:49 PM
Larry Rusch Larry Rusch is offline
go to www.baileigh.com
Old 02-20-2018, 02:15:10 PM
Thanks for the complements Big Bird! As far as baleigh tools go, I already have a few (wheel and a mag brake) but some of the tools made during the war effort just can稚 be beat! I found an original Yoder last month about an hour from me but the price was more than a new double head cast Pettingell
Old 02-21-2018, 09:46:17 AM
Check out a few of these sites.
Metalcraft tools. www.metalcrafttools.com decent price, good tools and tooling
Fournier, www.fournierenterprise.com
A little more pricey but good quality
Tce corporation. Phone # 800-886-2611. Call and request literature on sheet metal equipment..These guys sell Big boy tools and Shaper's...some of the best, expensive, Only if you have deep pockets.
Old 02-21-2018, 11:14:45 AM
Charlie I have several of the hand operated bench top machines for turning edges , beads . flanges. they come with extra wheels-shapes. They are rusty , need a lot of TLC. You can have them. Give me an Email or PM. Ron
The Following 3 Users Say Thank You to Ronald E. McClellan For This Post:
Old 09-24-2018, 02:49:05 PM
Corn Corn is offline
Charlie how about posting more pictures of your project
Old 10-22-2018, 09:51:18 PM
More stuff I have been working on:
Dodge rear fender buck
68 Mercury cougar lower repair panel made by hand:
Porsche road race door panels
On a side note, I have had some luck finding some tools but please keep an eye out! Looking for a power hammer and a pullmax. Wouldn’t mind a planishing hammer of a different configuration.
The Following 2 Users Say Thank You to charliesd250 For This Post:
Old 07-16-2019, 08:48:34 PM
Default Re: Young Metalshaper Looking for More Tools
Wanted to bump this up again. Still looking for a Pullmax and anything power hammer related. I have been working on the fender I made a buck for and various other sheetmetal projects. Lots of dent removal and metal finishing projects!
Charlie
ID:	339197   Click image for larger version
ID:	339198   Click image for larger version
ID:	339199   Click image for larger version
Old 07-16-2019, 08:57:04 PM
Here is some of the equipment I have since acquired and rebuilt or restored. The Baileigh english wheel I got from a shop that burned down. I disassembled it, blasted and replaced all bearings. Sent anvils out for grind and polish. Both TCE/Erco shrinkers received the same treatment. I知 looking for more dies for them. The planishing hammer I built using an Airboss #2 motor and an old band saw frame. A couple rotary shears have been fixed up as well. Wrapping up the restoration of a Chicago 30 ton press brake now. Took everything apart and cleaned/blasted and repainted. I take good care of the tools so I know they will take care of me for many years.
Charlie
ID:	339202   Click image for larger version
ID:	339204   Click image for larger version
The Following 6 Users Say Thank You to charliesd250 For This Post:
Old 08-09-2019, 12:13:01 AM
msellers msellers is offline
Here is another place to try. It never ceases to amaze what shows up here.
https://www.jimbodetools.com/
Old 08-09-2019, 07:19:28 AM
Peter Holmander Peter Holmander is offline
Charlie: I have a benchtop slip roller that needs a little tlc. I was going to clean it up and use it in my shop, but I really do not have the room for it. If you need one, come pick it up and it's yours. If you already have one, just disregard my post.
---------- Post added at 07:19:28 AM ---------- Previous post was at 07:18:26 AM ----------
Forgot to add that it is approximately 48 inches long.
Never too young Chris Epping Hit & Miss Gas Engine Discussion 9 05-28-2015 11:20:57 AM
old and young getting along Rod Fielder Antique Marine Engines and Outboard Motors 2 07-30-2011 10:18:03 PM
Tools tools and more info on those garage sale finds! PTSideshow Machine Shop and Tool Talk 2 08-26-2009 02:36:51 PM
