Go Back   SmokStak > SmokStak® Antique Engine Community > Oilers, Lubricators and Grease Cups
Oilers, Lubricators and Grease Cups Discussion about collecting and restoring oilers, lubricators & grease cups.
Leader Oiler Parts
this thread has 5 replies and has been viewed 627 times
Old 05-10-2018, 12:18:05 PM
jlhahn jlhahn is offline
Default Leader Oiler Parts
Can you buy replacement needle valve stems for a Leader oiler (see pics). I fired up the engine and opened the oiler and the handle came off in my hand. Thanks in advance.
ID:	310163   Click image for larger version
Old 05-10-2018, 12:29:38 PM
Default Re: Leader oiler parts
There aren't too many new parts available for oilers. Mostly glass ,gaskets, and fill plugs. The best way is to go to a show and usually someone has parts oilers etc. for sale. You may have to buy more than the needle to fix what you have. rob
Old 05-10-2018, 01:00:31 PM
You could silver solder the end up and make a new pin for the lever.
The Following 2 Users Say Thank You to Bill Hazzard For This Post:
Old 05-10-2018, 03:05:48 PM
Thanks for the ideas. Coolsprings is coming up on June 14, 15, 16. I missed it last year, I was thinking it was this one weekend and it was the one before. I'll check there this year since it will be in a month. Thanks again.
Old 05-10-2018, 10:59:25 PM
Default Re: Leader Oiler Parts
There are a few guys that bring oiler parts to CS. Bring along yours to fit parts. Sometimes the needle from a larger oiler can be cut down at the point to be made to work. Rob
Old 05-12-2018, 09:03:28 AM
If I would try the silver solder that Bill suggested first what could I use to make a new pin that would work? My brother does AC work and uses silver solder.
american oiler parts David A. Oil Field Engines & Related Equipment 0 03-02-2016 06:03:46 PM
Economy Oiler Parts Sad Iron Hit & Miss Gas Engine Discussion 4 03-25-2013 10:17:01 PM
Help need Manzel oiler parts newway1978 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 09-18-2010 02:48:50 AM
Leader Engine Parts Needed Paul Spence Antique Engine Archives 1 04-17-2002 04:09:45 PM
auyo oiler parts gearald fielder Antique Engine Archives 1 11-12-2000 09:20:28 PM
